[GeoNode-devel] Installing & configuring Geonode for production
Dimitris Karakostis karakostis.dimitris at gmail.com
Fri Feb 1 01:11:38 PST 2019
Thanks.
Olivier I will checkout out the Docker option. Toni I have managed to
configure everything. I was messing things up on the local_settings.py file.
On Thu, Jan 31, 2019 at 12:08 AM Olivier Dalang <olivier.dalang at gmail.com>
wrote:
> Hi,
> Did you consider this Docker setup :
> https://github.com/GeoNode/geonode/tree/master/scripts/spcgeonode ?
> It is meant to deploy Geonode for production is much easier than to
> reconfigure everything from scratch.
> Cheers,
> Olivier
> On Tue, Jan 29, 2019 at 9:26 AM Dimitris Karakostis <
> karakostis.dimitris at gmail.com> wrote:
>> I am following the instructions from here [1] to install Geonode 2.8 in a
>> Vagrant machine (ubuntu 16.04). I manage to complete all the steps without
>> any error but in the end of the installation & configuration process the
>> geonode page is not accessible (localhost or localhost:8000). But I am able
>> to access tomcat and geoserver (http://localhost:8080/geoserver/web/). I
>> have also followed the steps from Toni's video [2] and I have made sure
>> that I use the right user (in my case is "ubuntu" instead of "geo" or
>> "vagrant"). Also I have deactivate the apache conf files (000-default.conf)
>> and made sure to reload the server (sudo service apache2 reload).
>> The error.log does't say a lot either:
>> [Mon Jan 28 15:23:33.256516 2019] [mpm_event:notice] [pid 2648:tid
>> 140573263873920] AH00491: caught SIGTERM, shutting down
>> [Tue Jan 29 08:16:38.027075 2019] [wsgi:warn] [pid 1337:tid
>> 140030881531776] mod_wsgi: Compiled for Python/2.7.11.
>> [Tue Jan 29 08:16:38.028465 2019] [wsgi:warn] [pid 1337:tid
>> 140030881531776] mod_wsgi: Runtime using Python/2.7.12.
>> [Tue Jan 29 08:16:38.029659 2019] [mpm_event:notice] [pid 1337:tid
>> 140030881531776] AH00489: Apache/2.4.18 (Ubuntu) mod_wsgi/4.3.0
>> Python/2.7.12 configured -- resuming normal operations
>> [Tue Jan 29 08:16:38.029684 2019] [core:notice] [pid 1337:tid
>> 140030881531776] AH00094: Command line: '/usr/sbin/apache2'
>> Any advice on how to debug this?
>> [1]
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>> [2] https://vimeo.com/278003647#t=37m37s
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190201/aa73b3ec/attachment.html>
More information about the geonode-devel mailing list
