[GeoNode-users] help with geonode-geoexplorer layer query
Giovanni Albano albano.giovanni at tiscali.it
Fri Apr 3 22:41:40 PDT 2015
thank you for your response. the problem is that we have to integrate geonode with this feature. we have already decided to use geonode. now asked us to add this feature, and unfortunately we do not have development skills in Python. so we were looking for a simpler solution. but the answer that you gave me I think we have to find a developer to do this thing. that right?
> Il giorno 04/apr/2015, alle ore 00:08, GC-54 <nepanode at gmail.com> ha scritto:
> Albano it doesn't sound like Geonode is the problem nor the solution... Sounds like it'd be easier to look into a simple web map that you could pass the geoserver a WFS request; using some javascript or django forms to inject/append a CQL filter into... and use a format like GeoJSON which will load/focus the webmap to the feature when returned
> Trying to get Geoexplorer to do this sounds a bit bulky; and would require you to modified how maps get loaded/saved; is this scenario a reoccurring need for your data/use of Geonode?
More information about the geonode-users mailing list
