[GeoNode-users] Problems to migrate Geoserver from Geonode 2.0 to Geoserver from Geonode 2.4
Davi Custodio davicustodio at gmail.com
Thu Aug 13 05:59:19 PDT 2015
Hello. I'm having problems with the migration of the 2.0 version of GeoNode
Geoserver for Geoserver the GeoNode 2.4.
I copied the date and configured folder all that was needed for the
operation.
Only testing the Geoserver, I can access all of the layers normally and
including Layer Preview of each. Everything seems to work perfectly in
Geoserver.
But when I try to upload a shapefile by GeoNode 2.4, I get the following
message:
"An exception occurred loading data to PostGIS- Error while storing
uploaded file :: Input objects can not be null"
And in the log of Tomcat, attached
Does GeoNode 2.4 is not able to communicate with the Geoserver? When I run
a 'updatelayers GeoNode "everything works well.
Does anyone have any idea what might be causing the problem in the upload
of layers?
Thank you.
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150813/8f507450/attachment.html>
2015-08-13 09:46:20,654 INFO [catalog.rest] - PUT file, mimetype: application/zip
2015-08-13 09:46:20,665 ERROR [geoserver.rest] - Error while storing uploaded file::Input objects cannot be null
2015-08-13 09:46:20,669 ERROR [geoserver.rest] -
org.geoserver.rest.RestletException: java.lang.NullPointerException: Input objects cannot be null
	at org.geoserver.catalog.rest.StoreFileResource.handleFileUpload(StoreFileResource.java:137)
	at org.geoserver.catalog.rest.StoreFileResource.doFileUpload(StoreFileResource.java:96)
	at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:216)
	at org.restlet.Finder.handle(Finder.java:298)
	at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
	at org.restlet.Filter.doHandle(Filter.java:105)
	at org.restlet.Filter.handle(Filter.java:134)
	at org.restlet.Router.handle(Router.java:444)
	at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
	at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
	at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
	at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:800)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:649)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
	at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
	at org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at com.googlecode.psiprobe.Tomcat70AgentValve.invoke(Tomcat70AgentValve.java:38)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NullPointerException: Input objects cannot be null
	at org.geoserver.rest.util.IOUtils.inputNotNull(IOUtils.java:387)
	at org.geoserver.rest.util.IOUtils.closeQuietly(IOUtils.java:375)
	at org.geoserver.rest.util.RESTUtils.handleBinUpload(RESTUtils.java:156)
	at org.geoserver.rest.util.RESTUtils.handleBinUpload(RESTUtils.java:111)
	at org.geoserver.catalog.rest.StoreFileResource.handleFileUpload(StoreFileResource.java:119)
	... 93 more
2015-08-13 09:53:08,110 INFO [geoserver.security] - Strong cryptography is available
More information about the geonode-users mailing list
