[GeoNode-users] Problems to migrate Geoserver from Geonode 2.0 to Geoserver from Geonode 2.4
Davi Custodio davicustodio at gmail.com
Wed Aug 19 11:02:44 PDT 2015
Complementing information about the problem:
I'm trying to migrate Geoserver 2.4 (used by GeoNode 2.0) for GeoServer
2.5.1 (used by GeoNode 2.4).
I copied the folder "data" complete GeoServer 2.4, and assured that the
store "datastore" was pointing to the bank "geonode_data" and all layers
work properly within the GeoServer, including "Layer Preview".
The problem is happening when I try to upload any shapefile, where I get
the error message (see previous message) and the log of Tomcat.
I take to supplement, also putting the log generated by GeoNode 2.4 (below).
Can anyone help?
Thanks.
[Wed Aug 19 12: 58: 06.246992 2015] [: error] [pid 22552: tid
140,053,275,363,072] An exception occurred loading data to PostGIS- Error
while storing uploaded file :: Input objects can not be null
[Wed Aug 19 12: 58: 06.247093 2015] [: error] [pid 22552: tid
140,053,275,363,072] Traceback (most recent call last):
[Wed Aug 19 12: 58: 06.247107 2015] [: error] [pid 22552: tid
140,053,275,363,072] File
"/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py", line 163
, in layer_upload
[Wed Aug 19 12: 58: 06.247116 2015] [: error] [pid 22552: tid
140,053,275,363,072] title = form.cleaned_data ["layer_title"]
[Wed Aug 19 12: 58: 06.247123 2015] [: error] [pid 22552: tid
"/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py", line 398
, in file_upload
[Wed Aug 19 12: 58: 06.247130 2015] [: error] [pid 22552:
140,053,275,363,072 tid] = defaults defaults
[Wed Aug 19 12: 58: 06.247137 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/django/db/models/manager.py", line 154 ,
in get_or_create
[Wed Aug 19 12: 58: 06.247144 2015] [: error] [pid 22552: tid
140,053,275,363,072] return self.get_queryset () get_or_create (** kwargs).
[Wed Aug 19 12: 58: 06.247151 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/modeltranslation/manager.py", line 341,
in get_or_create
[Wed Aug 19 12: 58: 06.247158 2015] [: error] [pid 22552: tid
140,053,275,363,072] super return (MultilingualQuerySet, self)
.get_or_create (** kwargs)
[Wed Aug 19 12: 58: 06.247165 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/django/db/models/query.py", line 380 , in
get_or_create
[Wed Aug 19 12: 58: 06.247172 2015] [: error] [pid 22552: tid
140,053,275,363,072] obj.save (force_insert = True, using = self.db)
[Wed Aug 19 12: 58: 06.247179 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line
90, in save
[Wed Aug 19 12: 58: 06.247186 2015] [: error] [pid 22552: tid
140,053,275,363,072] super return (PolymorphicModel, self) .save (* args,
** kwargs)
[Wed Aug 19 12: 58: 06.247193 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 545 ,
save in
[Wed Aug 19 12: 58: 06.247200 2015] [: error] [pid 22552:
140,053,275,363,072 tid] = force_update force_update, update_fields =
update_fields)
[Wed Aug 19 12: 58: 06.247207 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 569 , in
save_base
[Wed Aug 19 12: 58: 06.247214 2015] [: error] [pid 22552:
140,053,275,363,072 tid] = update_fields update_fields)
[Wed Aug 19 12: 58: 06.247220 2015] [: error] [pid 22552: tid
"/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185,
in send
[Wed Aug 19 12: 58: 06.247227 2015] [: error] [pid 22552: tid
140,053,275,363,072] response = receiver (signal = self, sender = sender,
named **)
[Wed Aug 19 12: 58: 06.247234 2015] [: error] [pid 22552: tid
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
71 , in geoserver_pre_save
[Wed Aug 19 12: 58: 06.247241 2015] [: error] [pid 22552: tid
140,053,275,363,072] charset = instance.charset)
[Wed Aug 19 12: 58: 06.247248 2015] [: error] [pid 22552: tid
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
1041 , in geoserver_upload
[Wed Aug 19 12: 58: 06.247254 2015] [: error] [pid 22552:
140,053,275,363,072 tid] = overwrite overwrite)
[Wed Aug 19 12: 58: 06.247261 2015] [: error] [pid 22552: tid
951 , in _create_db_featurestore
[Wed Aug 19 12: 58: 06.247268 2015] [: error] [pid 22552: tid
140,053,275,363,072] raise GeoNodeException (msg)
[Wed Aug 19 12: 58: 06.247275 2015] [: error] [pid 22552: tid
140,053,275,363,072] GeoNodeException: An exception occurred loading data
to PostGIS- Error while storing uploaded file :: Input objects can not be
null
On Thu, Aug 13, 2015 at 9:59 AM, Davi Custodio <davicustodio at gmail.com>
wrote:
> Hello. I'm having problems with the migration of the 2.0 version of
> GeoNode Geoserver for Geoserver the GeoNode 2.4.
> I copied the date and configured folder all that was needed for the
> operation.
> Only testing the Geoserver, I can access all of the layers normally and
> including Layer Preview of each. Everything seems to work perfectly in
> Geoserver.
> But when I try to upload a shapefile by GeoNode 2.4, I get the following
> message:
> "An exception occurred loading data to PostGIS- Error while storing
> uploaded file :: Input objects can not be null"
> And in the log of Tomcat, attached
> Does GeoNode 2.4 is not able to communicate with the Geoserver? When I run
> a 'updatelayers GeoNode "everything works well.
> Does anyone have any idea what might be causing the problem in the upload
> of layers?
> Thank you.
> Davi de O. Custódio
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150819/870dcb60/attachment.html>
More information about the geonode-users mailing list
