[GeoNode-users] site_index.html not being included
    Francesco Bartoli
    xbartolone at gmail.com
    Tue Dec 22 07:34:05 PST 2015
Charles,
I confirm it's the recommended way. Trying to reproduce your issue.
Regards,
Francesco
> On Dec 22 2015, at 4:09 pm, Charles Cossé <ccosse at gmail.com> wrote:
> PS We are using geonode-project, yes.  So I think geonode-project's
site_index.html is being ignored for some reason when using geonode-project
with the new geonode release.
> We also tried the
[Dockerfile](https://github.com/GeoNode/geonode/blob/master/Dockerfile) for
comparison and I see there that the Dockerfile does not use geonode-project
(so no comparison possible).   Is geonode-project still the recommended way to
customize a geonode site?  It worked well with the last release candidate of
geonode, but not with the new geonode release.  Thanks in advance for more
help and suggestions,
> Charles
> On Tue, Dec 22, 2015 at 7:49 AM, Charles Cossé
<[ccosse at gmail.com](mailto:ccosse at gmail.com)> wrote:
>> Hi again, sorry for not being more clear.  All files are present but our
site_index.html is not being served.  Our modified front page worked well with
the last release candidate but with a fresh install of the new release
site_index.html is being ignored, which breaks our front page.  It can be
verified with just a string added to each of site_base and site_index.html and
noting that only the string from site_base.html shows up on the front page.
This is the conclusion we came to yesterday after much testing and checking.
I will triple check just in case.  Thank you,
>> -Charles
>> On Tue, Dec 22, 2015 at 4:32 AM, Francesco Bartoli
<[xbartolone at gmail.com](mailto:xbartolone at gmail.com)> wrote:
>>> Hi,
>>> The file is included in the version 2.4 of the repository:
>>> <https://github.com/GeoNode/geonode-
project/blob/master/project_name/templates/site_index.html>
>>> Did you run a fresh git clone for your project?
>>> Francesco
>>>> On Dec 22 2015, at 12:28 am, Charles Cossé
>>>> Hi, yes i am using geonode-project and site_base is being included
correctly but site_index is not.
>>>> On Dec 21, 2015 4:53 PM, "Francesco Bartoli"
>>>>> Hi Charles,
>>>>> site_index is a template from the geonode-project [1] and doesn’t
compare in the geonode code base. Essentially you can use it as an extension
of the template index.html and customize geonode
>>>>> Regards,
>>>>> Francesco
>>>>> [1] <https://github.com/GeoNode/geonode-project/>
>>>>> Il giorno 21/dic/2015, alle ore 21:22, Charles Cossé
<[ccosse at gmail.com](mailto:ccosse at gmail.com)> ha scritto:
>>>>>> Hi, using the new/recent 2.4 release I find that site_index.html is not
being included but site_base.html is.  Does anyone else see this happening?
Thanks,
>>>>>> Charles
>>>>>> _______________________________________________
geonode-users mailing list
[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
<http://lists.osgeo.org/mailman/listinfo/geonode-users>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151222/50bca11e/attachment.html>
More information about the geonode-users
