[GeoNode-users] Making Harvesting in a dedicated server PyCSW from catalogs CSW in GeoNode servers
Davi Custodio davicustodio at gmail.com
Fri Jun 19 11:26:30 PDT 2015
Oh. I'm sorry, I put the wrong url, where I talk about the first harvest
test:
http: // http: //demo.geonode.org//catalogue/csw
which actually is:
http://demo.geonode.org//catalogue/csw
.. And the error returned is:
Initializing static context
Executing HTTP POST request /var/www/html/pycsw/bin/request.xml on server
http: //localhost/pycsw/csw.py
   File "/usr/bin/pycsw-admin.py", line 246, in <module>
     print admin.post_xml (CSW_URL, XML, TIMEOUT)
   File "/usr/lib/python2.7/dist-packages/pycsw/admin.py", line 495, in
post_xml
     raise RuntimeError (err)
RuntimeError: timed out
Thank you.
On Fri, Jun 19, 2015 at 3:22 PM, Davi Custodio <davicustodio at gmail.com>
wrote:
> Hello. I have a scenario consists of 8 GeoNode servers with their
> respective PyCSW assets.
> To test, Getrecords use as:
> http://localhost/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary
> and receive the corresponding xml correctly.
> You can also configure the harvest within the Geonetwork using:
> http: // localhost / catalog / csw version = 2.0.2 & request =
> GetCapabilities & service = CSW
> and also the harvest runs properly.
> I created a dedicated server with the default installation of PyCSW
> 1.10.0, and I'm trying to get this server collect all the metadata records
> of 8 servers GeoNode.
> My intention is to have a PyCSW to gather all the metadata of my
> organization. I'm avoiding using "federatedcatalogues" because I do not
> want the user who will rep csw need to specify additional parameters.
> In a first test, I used the command:
> pycsw-admin.py -c -u post_xml http: -x //localhost/pycsw/csw.py
> where request.xml =
> <? Xml version = "1.0" encoding = "UTF-8"?>
> <Harvest xmlns = "http://www.opengis.net/cat/csw/2.0.2" xmlns: ogc = "
> http://www.opengis.net/ogc" xmlns: gmd = "http: // www .isotc211.org /
> 2005 / gmd "xmlns: ows =" http://www.opengis.net/ows "xmlns: xsd ="
> http://www.w3.org/2001/XMLSchema "xmlns: dc ="
> http://purl.org/dc/elements/1.1/ "xmlns: dct =" http://purl.org/dc/terms/
> "xmlns: gml =" http://www.opengis.net/gml " xmlns: xsi = "
> http://www.w3.org/2001/XMLSchema-instance" xsi: schemaLocation = "
> http://www.opengis.net/cat/csw/2.0.2 http: //schemas.opengis .net / csw /
> 2.0.2 / CSW-publication.xsd "service =" CSW "version =" 2.0.2 ">
>   <Source> http: // http: //demo.geonode.org//catalogue/csw </ Source>
>   <ResourceType> http://www.opengis.net/cat/csw/2.0.2 </ ResourceType>
>   <ResourceFormat> application / xml </ ResourceFormat>
> </ Harvest>
> pointing to http: // http: //demo.geonode.org//catalogue/csw ..
> I get the following error:
> <? Xml version = "1.0" encoding = "UTF-8" standalone = "no"?>
> <! - Pycsw 1.10.0 ->
> <Ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/"
> xmlns: inspire_common = "http://inspire.ec.europa.eu/schemas/common/1.0"
> xmlns: atom = "http://www.w3.org/2005/Atom" xmlns: xs = "
> http://www.w3.org/2001/XMLSchema" xmlns: dct = "http://purl.org/dc/ terms
> / "xmlns: ows =" http://www.opengis.net/ows "xmlns: apiso ="
> http://www.opengis.net/cat/csw/apiso/1.0 "xmlns: gml =" http: //
> www.opengis.net/gml "xmlns: diff ="
> http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ "xmlns: xlink ="
> http://www.w3.org/1999 / xlink "xmlns: gco ="
> http://www.isotc211.org/2005/gco "xmlns: gmd =" ​​
> http://www.isotc211.org/2005/gmd "xmlns: rdf =" http: //
> www.w3.org/1999/02/22-rdf-syntax-ns# "xmlns: srv ="
> http://www.isotc211.org/2005/srv "xmlns: ogc =" http: //www.opengis .net
> / ogc "xmlns: FGDC =" http://www.opengis.net/cat/csw/csdgm "xmlns:
> inspire_ds =" http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 "xmlns :
> csw = "http://www.opengis.net/cat/csw/2.0.2" xmlns: xsi = "
> http://www.w3.org/2001/XMLSchema-instance" xmlns: the = "http: //
> a9.com/-/spec/opensearch/1.1/ "xmlns: soapenv ="
> http://www.w3.org/2003/05/soap-envelope "xmlns: sitemap =" http:
> //www.sitemaps .org / schemas / sitemap / 0.9 "language =" en-US "version
> =" 1.2.0 "xsi: schemaLocation =" http://www.opengis.net/ows
> http://schemas.opengis.net/ows
> /1.0.0/owsExceptionReport.xsd"><ows:Exception ExceptionCode =
> "NoApplicableCode" locator = "service"> <ows: ExceptionText> Exception: the
> document is not valid.
> Error: Element '{http://www.opengis.net/cat/csw/2.0.2}Source': 'http: //
> http: //demo.geonode.org//catalogue/csw' is not a valid value of the
> atomic type. 'xs: anyURI' </ ows: ExceptionText> </ ows: Exception> </ ows:
> ExceptionReport>
> Done
> when I point to one of my GeoNode-PyCSW servers using request.xml as:
>   <Source> http://aguai.cnpm.embrapa.br/catalogue/csw </ Source>
> </ Harvest>
> pointing to my server: http://aguai.cnpm.embrapa.br/catalogue/csw
> I get the error:
> "NoApplicableCode" locator = "source"> <ows: ExceptionText> Harvest
> (insert) failed: ERROR: null value in column "identifier" violates not-null
> constraint
> DETAIL: Failing row contains (null, csw: Record,
> http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-19T15: 19: 28Z & lt;
> ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" ...
> Missing keyword: service, null, null, null, null, null, null, null, null,
> null, null, null, null, null, null, null, null, null, null, null, null,
> http://aguai.cnpm.embrapa.br/catalogue/csw, null, null, null, null, null,
> null, null, null, null, null, 'keyword': 2 'miss': 1' servic '3, null).
> . </ Ows: ExceptionText> </ ows: Exception> </ ows: ExceptionReport>
> Done
> Can anyone help me explaining how to best implement it? And because of
> errors?
> Davi de O. Custódio
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150619/4a399245/attachment-0001.html>
More information about the geonode-users mailing list
