[GeoNode-users] upload, WMS and permission errors
Gavin Fleming gavin at kartoza.com
Tue Mar 10 23:52:21 PDT 2015
Ariel
On 10/03/2015 18:11, Ariel Nunez wrote:
> Gavin,
> I'll try to come up with possible explanations for the errors you are
> seeing:
> 1) This happens from time to time, especially with big files over slow
> networks. A timeout occurs and then the web page stops listening for
> the json return, even though it all went fine. The best way to deal
> with this in the future is to switch to asyncronous
> upload/configuration and do some sort of polling.
OK
> 2) You got no error from the upload widget? Was there anything in the
> logs? We improved this for 2.4 adding a place in the django admin
> where you can go to look for failed uploads and keeps the geoserver
> log and the django log. But it is not available in 2.0
There are some permission errors in the logs.
I set this up after the workshop, I wonder if it's causing any issues:
http://docs.geonode.org/en/2.0/tutorials/admin/production.html#security-integration-optimization
> 3) Not sure what could be going on.
> 4) Also no idea
> 5) To me, the problem could be in the geoserver-geonode-ext plugin.
> That is the plugin for geoserver that handles the authentication, and
> it could be misbehaving. potentially due to lack of resources (too
> little ram). What is your configuration?
16GB RAM, shared with other apps. 8 x 1.6GHz processors. No disk space
limitations.
> Something sounds bad there, but my recommendation is to run 2.4
> instead, we are getting close to a release and I would advice against
> having to migrate in a few months. The pros of using 2.4 over 2.0
> outweigh the cons (IMHO).
I'd like to. I have it running on my local 14.10. Are there 2.4 testing
packages for precise? apt is not picking any up.
> -a
> On Tue, Mar 10, 2015 at 10:59 AM, Gavin Fleming <gavin at kartoza.com
> <mailto:gavin at kartoza.com>> wrote:
>     :buildings_osm_maumere
> That part should probably have been workspace:layer_name (or
> geonode:buildings_osm_maumere)
> The fact that there is no workspace indicates there could have been a
> problem.
Yes it should have the workspace but geonode is not inserting the
workspace name.
thanks
Gavin
Gavin Fleming Joint MD PGP 1234
Visit http://kartoza.com <http://kartoza.com/>to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: phlemingo
Kartoza = Linfiniti ∪ Afrispatial
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150311/3f7f53b3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150311/3f7f53b3/attachment-0001.png>
More information about the geonode-users mailing list
