[GeoNode-users] Fwd: Layer styles not updatable 2.4b25
Rainer Lissewski rainerlissewski at gmail.com
Thu May 28 00:58:52 PDT 2015
It happens mostly with quite big layers (say > 5000 points) . As said in
https://github.com/GeoNode/geonode/issues/2031#issuecomment-106215309 it is
connected wit a PUT request not being replied by the server.
2015-05-12 13:37 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hm, I'd really like to sort this out. :) but I need to find the way to
> replicate it. Thanks for the debug so far.
> 2015-05-12 13:33 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>> i am using 2.4b25 as installed from ppa geonode/testing on trusty lts
>> _____________________________________
>> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
>> Linux, GIS and database developer team
>> Wittmannsdorfer Str. 4
>> 12053 Berlin
>> Germany / Allemagne
>> Tel.: +49 (0) 30 28 45 40 71
>> Mobil: +49 (0) 163 681 77 34
>> Fax: +49 (0)30 / 48 49 81 286
>> 2015-05-12 13:26 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> I don't see errors, I'm also trying to replicate both locally and on
>>> demo.geonode.org but every created style works fine.
>>> Are you using the last geonode b25 or something older?
>>> 2015-05-12 12:20 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>> Hi , all styles were created in geonode GUI, so no pattern there.
>>>> also now errors in stacktrace
>>>>     AXIS["Latitude", NORTH],
>>>>     AUTHORITY["EPSG","4326"]],
>>>>   PROJECTION["Mercator_1SP"],
>>>>   PARAMETER["semi_minor", 6378137.0],
>>>>   PARAMETER["latitude_of_origin", 0.0],
>>>>   PARAMETER["central_meridian", 0.0],
>>>>   PARAMETER["scale_factor", 1.0],
>>>>   PARAMETER["false_easting", 0.0],
>>>>   PARAMETER["false_northing", 0.0],
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>>   AUTHORITY["EPSG","900913"]]
>>>> Bbox = SRSEnvelope[1056665.4788672 : 1066449.4184863, 7122708.0427344
>>>> : 7132491.9823535]
>>>> RemoteOwsType = null
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>> Transparent = true
>>>> SldBody = null
>>>> ValidateSchema = false
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BaseUrl = http://xx.x.x.x:xxxxx/geoserver/
>>>> RawKvp = {_OLSALT=0.9492145837284625, _DC=0.7638796556275338,
>>>> BBOX=1056665.4788672,7122708.0427344,1066449.4184863,7132491.9823535,
>>>> SERVICE=WMS, TILED=true, HEIGHT=256, REQUEST=GetMap,
>>>> STYLES=style1_3d7625b4, WIDTH=256, TRANSPARENT=TRUE, VERSION=1.1.1,
>>>> FORMAT=image/png, LAYERS=geonode:layer11, SRS=EPSG:900913}
>>>> RequestCharset = UTF-8
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,436 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> Layers = [org.geoserver.wms.MapLayerInfo at edaec8d6]
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>> FeatureVersion = null
>>>> Styles = [StyleImpl[ name=style1_3d7625b4]]
>>>> Crs = PROJCS["WGS84 / Google Mercator",
>>>>   GEOGCS["WGS 84",
>>>>     DATUM["World Geodetic System 1984",
>>>>       SPHEROID["WGS 84", 6378137.0, 298.257223563,
>>>> AUTHORITY["EPSG","7030"]],
>>>>       AUTHORITY["EPSG","6326"]],
>>>>     PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
>>>>     UNIT["degree", 0.017453292519943295],
>>>>     AXIS["Longitude", EAST],
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7103140.1634961 :
>>>> 7112924.1031152]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1046881.539248,7103140.1634961,1056665.4788672,7112924.1031152,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,445 INFO [geoserver.wms] -
>>>> Request: getServiceInfo
>>>> 2015-05-12 10:10:25,446 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7093356.223877 :
>>>> 7103140.1634961]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1046881.539248,7093356.223877,1056665.4788672,7103140.1634961,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,483 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,490 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7112924.1031152 :
>>>> 7122708.0427344]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1046881.539248,7112924.1031152,1056665.4788672,7122708.0427344,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,503 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,511 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7083572.2842578 :
>>>> 7093356.223877]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1086017.2977246,7083572.2842578,1095801.2373438,7093356.223877,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,515 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,517 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7122708.0427344
>>>> : 7132491.9823535]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1086017.2977246,7122708.0427344,1095801.2373438,7132491.9823535,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,528 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,530 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,538 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,547 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 512
>>>> Height = 1024
>>>> MaxFeatures = null
>>>> Tiled = false
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323,
>>>> 7083572.284257814 : 7122708.042734373]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BaseUrl = http://localhost:8080/geoserver/
>>>> RawKvp =
>>>> {BBOX=1095801.237343751,7083572.284257814,1115369.1165820323,7122708.
>>>> 042734373, SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap,
>>>> STYLES=style1_3d7625b4, WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true,
>>>> VERSION=1.1.1, FORMAT=image/png, GWC_SEED_INTERCEPT=true,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,560 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,580 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7093356.223877 :
>>>> 7103140.1634961]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1095801.2373438,7093356.223877,1105585.1769629,7103140.1634961,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,581 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7112924.1031152 :
>>>> 7122708.0427344]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1095801.2373438,7112924.1031152,1105585.1769629,7122708.0427344,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7103140.1634961 :
>>>> 7112924.1031152]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1095801.2373438,7103140.1634961,1105585.1769629,7112924.1031152,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,762 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,767 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,770 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7083572.2842578 :
>>>> 7093356.223877]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1095801.2373438,7083572.2842578,1105585.1769629,7093356.223877,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,773 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7083572.2842578 :
>>>> 7093356.223877]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1046881.539248,7083572.2842578,1056665.4788672,7093356.223877,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,774 INFO [geoserver.wms] -
>>>> 2015-05-12 10:10:25,785 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 1024
>>>> Height = 1024
>>>> MaxFeatures = null
>>>> Tiled = false
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1017529.7203906253 : 1056665.478867188, 7122708.
>>>> 042734373 : 7161843.801210936]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> RawKvp = {BBOX=1017529.7203906253,7122708.042734373,1056665.478867188,7161843.801210936,
>>>> SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap, STYLES=style1_3d7625b4,
>>>> WIDTH=1024, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
>>>> FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=geonode:layer11,
>>>> SRS=EPSG:900913}
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 512
>>>> Height = 1024
>>>> MaxFeatures = null
>>>> Tiled = false
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323, 7122708.
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> RawKvp = {BBOX=1095801.237343751,7122708.042734373,1115369.1165820323,7161843.801210936,
>>>> WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
>>>> SRS=EPSG:900913}
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,804 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7122708.0427344
>>>> : 7132491.9823535]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1095801.2373438,7122708.0427344,1105585.1769629,7132491.9823535,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 2015-05-12 10:10:25,825 INFO [geoserver.wms] -
>>>> Request: getMap
>>>> Exceptions = SE_XML
>>>> Width = 256
>>>> Height = 256
>>>> MaxFeatures = null
>>>> Tiled = true
>>>> Palette = null
>>>> SRS = EPSG:900913
>>>>   GEOGCS["WGS 84",
>>>>   UNIT["m", 1.0],
>>>>   AXIS["x", EAST],
>>>>   AXIS["y", NORTH],
>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7122708.0427344 :
>>>> 7132491.9823535]
>>>> RemoteOwsURL = null
>>>> Env = {}
>>>> FormatOptions = {}
>>>> Angle = 0.0
>>>> CQLFilter = null
>>>> Elevation = []
>>>> FeatureId = null
>>>> StartIndex = null
>>>> ViewParams = null
>>>> Transparent = true
>>>> SldBody = null
>>>> Sld = null
>>>> SldVersion = null
>>>> TilesOrigin = null
>>>> Buffer = 0
>>>> Format = image/png
>>>> Time = []
>>>> Filter = null
>>>> Filters = null
>>>> Get = true
>>>> BBOX=1046881.539248,7122708.0427344,1056665.4788672,7132491.9823535,
>>>> Version = 1.1.1
>>>> Request = GetMap
>>>> 12053 Berlin
>>>> Germany / Allemagne
>>>> 2015-05-12 11:55 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> that is indeed strange, it doesn't look at a permission bug. They ones
>>>>> with no (none) might have a space instead. Do you have more information on
>>>>> how you created those styles?
>>>>> 2015-05-12 11:47 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>>> okay I found a pattern now:
>>>>>> in /admin/layers/style/
>>>>>> [image: Inline-Bild 1]
>>>>>> -The styles that have  "(None)" entry in the Workspace column  can be
>>>>>> edited via geonode style editor
>>>>>> -The styles that have no "(None)" entry entry in the Workspace column
>>>>>>  canot be edited via geonode style editor
>>>>>> How ever if i open a particular style in  /admin/layers/style/ , the
>>>>>> workspace field is empty for all stlyes, wether they have a "(None)" entry
>>>>>> in the Workspace column or not.
>>>>>> Is this a bug with the django permissions system?
>>>>>> 12053 Berlin
>>>>>> Germany / Allemagne
>>>>>> 2015-05-12 11:27 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>
>>>>>>> I have unticked the option "Automatic caching for non-standard
>>>>>>> styles" in
>>>>>>> /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.gwc.web.GWCSettingsPage
>>>>>>> That resolved the issue for a number of layers but not for all. The
>>>>>>> style for one point layer n my installation is still only editable in
>>>>>>> geoserver via SLD, not via geonode gui.
>>>>>>> 2015-05-12 10:43 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu
>>>>>>>> hmm. The only difference I can see is that, here,  the problem
>>>>>>>> occurs with a point layer
>>>>>>>> 12053 Berlin
>>>>>>>> Germany / Allemagne
>>>>>>>> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <
>>>>>>>>> Rainer, I'm testing this here
>>>>>>>>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't
>>>>>>>>> replicate.
>>>>>>>>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <
>>>>>>>>> rainerlissewski at gmail.com>:
>>>>>>>>>> Open a layer, edit layer, edit style. In the popup, select rule
>>>>>>>>>> and edit. Change color and/or opacity. Save and close. Repeat process, the
>>>>>>>>>> rule has reverted back to its original style.
>>>>>>>>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/458a8334/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/458a8334/attachment-0001.png>
More information about the geonode-users mailing list
