[GeoNode-users] Error accesing geonode
David Alda Fernandez de Lezea dalda at hazi.eus
Mon Nov 16 00:44:32 PST 2015
Hi Simone,
I had it working normally before I started modifying all the look and feel part. Indeed, I haven't changed anything to pint to sqllite.
I also have my local_settigns.py customized and it was working fine. How can I point the app to my settings file ?
By the way I forgot to put the link with the instructions I followed: https://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: lunes, 16 de noviembre de 2015 9:37
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Error accesing geonode
Hi David,
it seems that your settings file is not configured with the correct database. Is trying to access a file so it's likely that is configured to use sqllite.
Regards
2015-11-16 9:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi list,
I've been trying to customize the look and feel of my geonode following the instructions in  . After configuring several options and not achieving to get anything working y decide to rollback, but now while accessing my geonode app y get the following error:
OperationalError at /
unable to open database file
Request Method: GET
Request URL:    http://192.168.1.190/
Django Version: 1.6.10
Exception Type: OperationalError
Exception Value:
Exception Location:     /usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py in get_new_connection, line 347
Python Executable:      /usr/bin/python
Python Version: 2.7.3
Python Path:
['/usr/lib/python2.7',
 '/usr/lib/python2.7/plat-linux2',
 '/usr/lib/python2.7/lib-tk',
 '/usr/lib/python2.7/lib-old',
 '/usr/lib/python2.7/lib-dynload',
 '/usr/local/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages/PIL',
 '/usr/lib/python2.7/dist-packages/gst-0.10',
 '/usr/lib/python2.7/dist-packages/gtk-2.0',
 '/usr/lib/pymodules/python2.7',
 '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
 '/usr/lib/python2.7/dist-packages/ubuntuone-client',
 '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
 '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
 '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
 '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
 '/var/www']
Server time:    Mon, 16 Nov 2015 02:16:42 -0600
I can access GeoServer though.
Any ideas? Thanks in advance.
Regards,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
More information about the geonode-users mailing list
