[GeoNode-users] GeoNode/GeoServer update issue
Francesco Marigliano f.marigliano.it at ieee.org
Mon Nov 23 01:12:05 PST 2015
Il 23/11/2015 10:04, Simone Dalmasso ha scritto:
> Hi Francesco, seems a communication issue between geoserver and
> geonode. Can you take a look at the geoserver logs?
Here you are
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
     at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
     at
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
     at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
     at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: HTTPClient::sendGET: GeoNode
communication failed, status report is: 404, Not Found,
http://localhost/layers/acls
     at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:95)
     at
org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
     at
org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
     at
org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
> in case chack that /he WEB-INF/web.xml file of geoserver points to the
> correct geonode address.
Did you mean "PROXY_BASE_URL" field?
> 2015-11-23 9:48 GMT+01:00 Francesco Marigliano
> <f.marigliano.it at ieee.org <mailto:f.marigliano.it at ieee.org>>:
>     Hi all,
>     I recently updated GeoNode to /2.4c4, /after that if I'm not
>     logged into GeoServer I can't see any layer in GeoExplorer.
>     Just checked /local_settings.py /it seems to be everything ok.
>     Avast logo <https://www.avast.com/antivirus>
>     Questa e-mail è stata controllata per individuare virus con Avast
>     antivirus.
>     www.avast.com <https://www.avast.com/antivirus>
>     _______________________________________________
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Questa e-mail è stata controllata per individuare virus con Avast antivirus.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/56eecf6d/attachment.html>
More information about the geonode-users mailing list
