[GeoNode-users] Just installed Geonode, one question
Simone Dalmasso simone.dalmasso at gmail.com
Tue Oct 20 12:14:01 PDT 2015
I guess it overwrote the entire site and you have to include the old one as
well. The geonode custom install docs may help you.
Il martedì 20 ottobre 2015, Gisli Palsson <gisli.palsson at umu.se> ha scritto:
> Thanks for the response Simone. I have been trying to change the server
> name to get around this.
> Tried going from ‘servername localhost’ to ‘servername geonode.localhost’
> but that doesn’t do the trick. Anyone know?
> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>]
> *Sent:* 20 October 2015 20:59
> *To:* Gisli Palsson <gisli.palsson at umu.se
> <javascript:_e(%7B%7D,'cvml','gisli.palsson at umu.se');>>
> *Cc:* geonode-users at lists.osgeo.org
> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
> *Subject:* Re: [GeoNode-users] Just installed Geonode, one question
> Hi as stated in the docs geonode installed via apt-get should be installed
> in a clean environment. Probably it just changed the Apache default site
> but might not be the only thing. /etc/apache/sites-enabled
> Hope this helps
> <javascript:_e(%7B%7D,'cvml','gisli.palsson at umu.se');>> ha scritto:
> Hey,
> I just installed Geonode onto a system that I’m planning on using for two
> applications. The Geonode works fine, but the other (Omeka) installed at
> var/www/omeka isn’t being served to the internet. Instead, Geonode takes
> over the entire site. There isn’t anything obvious in the documentation to
> solve this.
> I’m not sure how to fix this, any help appreciated!
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151020/b61cfcbe/attachment.html>
More information about the geonode-users mailing list
