[GeoNode-users] syncdb problem
Eugenio Trumpy frippe12573 at hotmail.com
Wed Oct 28 08:20:10 PDT 2015
Dear all,
I solved this issue I think was due to different version of django and geonode schema,
by the way I remove all the packages installed via pip including django and I reinstalled
each package by using:
sudo pip install -e .
then I sincronized the db
and everything was ok.
To syncdb I gave:
python manage.py syncdb --noinput
without --all as suggeste in the guide, was that a problem?
best
Eugenio
Date: Wed, 28 Oct 2015 14:47:49 +0100
Subject: Re: syncdb problem
To: frippe12573 at hotmail.com
CC: geonode-users at lists.osgeo.org
Which version of python-six you have. I has to be the 1.5.2, check it with:$ pip freeze | grep six
2015-10-28 14:40 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi Simone,
I added this package, which was missing, however after the installation
I run again
and I got the same error lines.
E.
Date: Wed, 28 Oct 2015 14:32:12 +0100
Eugenio, $ sudo apt-get install python-django-autocomplete-light
should fix it.
2015-10-28 14:22 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Dear all,
I'm trying (again) to complete the installation and the test of the current geonode version 2.4.dev20151023111102.
After a test on vagrant box, which run fine, I upgraded the software versions on my server machine.
Now I have Ubuntu sserver at 14.04 version, apache2 is at 2.4.7 version, postgresql-postgis 9.3 (2.1) all of them installed from packages and tomcat7 installed manually.
As usual I followed the guide:
http://docs.geonode.org/en/latest/tutorials/admin/install/custom_install.html#custom-install
Currently I have a problem on:
which gave me this output:
http://paste.ubuntu.com/12988689/
The only difference is that I have postgresql listening on 5433 port instead the default. Of course I set the different post in the local_setting.py file.
Any suggestions?
thanks
Eugenio
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151028/86d7c82a/attachment.html>
More information about the geonode-users mailing list
