[GeoNode-users] Geoserver version and requirements
Eugenio Trumpy frippe12573 at hotmail.com
Thu Sep 24 03:46:32 PDT 2015
Hi Simone,
thank you for your hints.
On regard the first issue, you are right webapp-replica is a clone container of tomcat6, actually monitor does not exist,
it exists in the first tomcat6 container.
On regard the second problem I update the system installing openJDK-7, then I updated the java alternatives
and I restarted both tomcat6 and tomcat6-replica, however the same error still exist.
E.
> From: simone.giannecchini at geo-solutions.it
> Date: Thu, 24 Sep 2015 11:48:07 +0200
> Subject: Re: [GeoNode-users] Geoserver version and requirements
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> Ciao Eugenio,
> I see two errors:
> -1- you probably using an existing tomcat installation or a clone of it.
> Which references this path that does not exists:
> /dati/webapps-replica/monitor
> This should not be a blocker.
> -2- you are probably deploying a 2.7.x (can you confirm) instance of
> GeoServer using java6:
> java.lang.UnsupportedClassVersionError:
> org/geoserver/GeoserverInitStartupListener : Unsupported major.minor
> version 51.0 (unable to load class
> org.geoserver.GeoserverInitStartupListener)
> You can have multiple java version on the same machine. You need to
> have this tomcat using java 7.
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> On Thu, Sep 24, 2015 at 11:20 AM, Eugenio Trumpy
> <frippe12573 at hotmail.com> wrote:
> > Dear all,
> > for many reasons I had to configure two tomcat6 containers since I have
> > to manage two different geoserver:
> > first geoserver (G1) is an original version 2.3.2, which is running
> > correctly in the first container of tomcat6. This geoserver the one I use to
> > spread spatial dataset on behalf of my organization
> > second geoserver (G2) istance is the version I took from geonode
> > installation (from downloaded directory), and I put it on the second tomcat6
> > container.
> > Unfortunately G2 is not running, although the second tomcat6 container runs
> > fine (I tested a sample application downloaded from the web and I tried
> > there a normal geoserver application (vs.2.3.2), the G2 took from the
> > geonode istallation give me the error here below:
> > 4-set-2015 11.15.40 org.apache.catalina.core.StandardService stop
> > INFO: Stopping service Catalina
> > 24-set-2015 11.15.40 org.apache.coyote.http11.Http11Protocol destroy
> > INFO: Stopping Coyote HTTP/1.1 on http-8081
> > CompilerOracle: unrecognized line
> >   "exclude net/sf/saxon/event/ReceivingContentHandler startElement'"
> >   Unrecognized text after command: '
> > 24-set-2015 11.15.48 org.apache.catalina.startup.ClassLoaderFactory
> > validateFile
> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/server/classes],
> > exists: [false], isDirectory: [false], canRead: [false]
> > validateFile
> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/server], exists:
> > validateFile
> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/shared/classes],
> > validateFile
> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/shared], exists:
> > 24-set-2015 11.15.49 org.apache.coyote.http11.Http11Protocol init
> > INFO: Initializing Coyote HTTP/1.1 on http-8081
> > 24-set-2015 11.15.49 org.apache.catalina.startup.Catalina load
> > INFO: Initialization processed in 785 ms
> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardService start
> > INFO: Starting service Catalina
> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardEngine start
> > INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
> > 24-set-2015 11.15.49 org.apache.catalina.startup.HostConfig deployDescriptor
> > INFO: Deploying configuration descriptor monitor.xml
> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardContext resourcesStart
> > GRAVE: Error starting static Resources
> > java.lang.IllegalArgumentException: Document base
> > /dati/webapps-replica/monitor does not exist or is not a readable directory
> >     at
> > org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:142)
> >     at
> > org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:4320)
> >     at
> > org.apache.catalina.core.StandardContext.start(StandardContext.java:4489)
> >     at
> > org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
> >     at
> > org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
> >     at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
> >     at
> > org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:675)
> >     at
> > org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:601)
> >     at
> > org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:502)
> >     at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
> >     at
> > org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
> >     at
> > org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
> >     at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
> >     at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
> >     at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
> >     at
> > org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
> >     at
> > org.apache.catalina.core.StandardService.start(StandardService.java:525)
> >     at
> > org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
> >     at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
> >     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> >     at
> > sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> >     at
> > sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> >     at java.lang.reflect.Method.invoke(Method.java:622)
> >     at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
> >     at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardContext start
> > GRAVE: Error in resourceStart()
> > GRAVE: Error getConfigured
> > GRAVE: Context [/monitor] startup failed due to previous errors
> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardContext stop
> > INFO: Container
> > org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/monitor] has
> > not been started
> > 24-set-2015 11.15.49 org.apache.catalina.startup.HostConfig deployWAR
> > INFO: Deploying web application archive sample.war
> > INFO: Deploying web application archive geoserver.war
> > 24-set-2015 11.15.50 org.apache.catalina.loader.WebappClassLoader
> > validateJarFile
> > INFO:
> > validateJarFile(/dati/webapps-replica/geoserver/WEB-INF/lib/servlet-api-2.5.jar)
> > - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class:
> > javax/servlet/Servlet.class
> > 24-set-2015 11.15.50 org.apache.tomcat.util.modeler.Registry
> > registerComponent
> > GRAVE: Null component
> > Catalina:type=JspMonitor,name=jsp,WebModule=//localhost/geoserver,J2EEApplication=none,J2EEServer=none
> > 24-set-2015 11.15.50 org.apache.catalina.startup.HostConfig deployWAR
> > GRAVE: Error deploying web application archive geoserver.war
> > org/geoserver/GeoserverInitStartupListener : Unsupported major.minor version
> > 51.0 (unable to load class org.geoserver.GeoserverInitStartupListener)
> >     at
> > org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2822)
> >     at
> > org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1159)
> >     at
> > org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1647)
> >     at
> > org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
> >     at
> > org.apache.catalina.startup.WebAnnotationSet.loadClassAnnotation(WebAnnotationSet.java:145)
> >     at
> > org.apache.catalina.startup.WebAnnotationSet.loadApplicationListenerAnnotations(WebAnnotationSet.java:73)
> >     at
> > org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:56)
> >     at
> > org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:297)
> >     at
> > org.apache.catalina.startup.ContextConfig.start(ContextConfig.java:1078)
> >     at
> > org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:261)
> >     at
> >     at
> > org.apache.catalina.core.StandardContext.start(StandardContext.java:4612)
> >     at
> >     at
> >     at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
> >     at
> > org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:778)
> >     at
> > org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:504)
> >     at
> >     at
> >     at
> >     at
> >     at
> >     at
> >     at
> > 24-set-2015 11.15.50 org.apache.coyote.http11.Http11Protocol start
> > INFO: Starting Coyote HTTP/1.1 on http-8081
> > 24-set-2015 11.15.50 org.apache.catalina.startup.Catalina start
> > I searched something on the net and this problem should be related to
> > different version of tomcat/java JDK/geoserver
> > is that right?
> > My server is an Ubuntu 12.04, tomcat is at version 6, and java is
> > java-6-openjdk-amd64
> > Is that a right config?
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150924/55193ba7/attachment.html>
More information about the geonode-users mailing list
