[GeoNode-users] Is there a way to make queries on the map viewer?
Melvin Ramos melvin.ramos1991 at gmail.com
Tue Sep 29 09:25:27 PDT 2015
Hi Simone,
Indeed there is a query tool, but those are made against the attribute
table of the layer (and assuming multiple layers as well). The thing is
that in this case, relevant information is outside that table (some in the
metadata and some in custom classes I created), but you can't query on it
inside the map, so far I can query outside (I developed query filters using
angular, like the ones already programmed). My question is that if that
kind of querying has ever been implemented (and if so, how?) or even if it
has been given a thought.
Enviado con MailTrack
<https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
2015-09-29 11:36 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Melvin,
> there is a query tool in the map composer that you can use to filter a
> layer based on it's field.
> 2015-09-29 17:43 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
>> Hello community,
>> Is there a way to query inside the map viewer using the information
>> (metadata or even custom classes) linked to a layer? For example, all the
>> layers associated with a map belonging to an specific continent, or all the
>> layers who have some specific feature. It is to my understanding that the
>> map viewer is OpenLayers, does it support that kind of queries?
>> Thanks in advance
>> Melvin David Ramos Macías
>> 07-41408
>> Ingeniería de Computación
>> Universidad Simón Bolívar
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
07-41408
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150929/4c1d71c6/attachment-0001.html>
More information about the geonode-users mailing list
