[GeoNode-users] Install Geoserver from WAR (running on Tomcat)
Jorge de Jesus jorge.jesus at gmail.com
Tue Apr 5 01:45:13 PDT 2016
Hi Simone
Thank you for the tips I am now checking it out
I also found the WAR here
http://build.geonode.org/geoserver/latest/
Cheers
Jorge
On Tue, Apr 5, 2016 at 10:39 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Jorge,
> you can take the downloaded war and drop into the desired server. The you
> have to correct the OGC_SERVER location, in your settings, to point to the
> external geoserver address and tell geoserver where geonode is in
> date/security/auth/geonodeAuthProvider/config.xml (by default is localhost)
> A standard geoserver is also supported at the price of loosing the
> permissions system.
> Hope this helps
> 2016-04-05 9:30 GMT+02:00 Jorge de Jesus <jorge.jesus at gmail.com>:
>> Hi to all
>> I was wondering how to make a geoserver install (mainly WAR file drop) in
>> another server instead of the one running geonode.
>>  I see that paver downloads geoserver and makes the complete install with
>> all the libs/requirements necessary for genode integration. Is there
>> documentation on how this can be done manually and/or the requirements for
>> a geoserver compatible with geonode
>> Thank you
>> Jorge de Jesus
>> OpenPGP Key: 0x7212572C
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160405/ac682750/attachment.html>
More information about the geonode-users mailing list
