[GeoNode-users] Error creating style again
David Alda Fernandez de Lezea dalda at hazi.eus
Fri Apr 8 00:33:27 PDT 2016
I'm now getting an error when trying to create a new style from the GeoExplorer view. I'm getting a 403 forbidden error at the following lines
deleteStyles: function() {
        for (var i=0, len=this.deletedStyles.length; i<len; ++i) {
            Ext.Ajax.request({
                method: "DELETE",
                url: this.baseUrl + "/styles/" + this.deletedStyles[i] +
                    // cannot use params for DELETE requests without jsonData
                    "?purge=true"
        this.deletedStyles = [];
http://192.168.1.190/gs/rest/styles/bandaancha?purge=true 403 Can't delete style referenced by existing layers.
This is only happening with some layers.
What's the purpose of this function? Which are the supposed grants to be in the styles directory for each SLD?
Any ideas?
Thanks in advance.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
More information about the geonode-users mailing list
