[GeoNode-users] Geoserver data directory lost
Israel López asralf at gmail.com
Tue Apr 19 11:14:53 PDT 2016
Could you tell me how to do it Paolo?? Because I had to remade it one by
one again...
El abr. 18, 2016 9:44, "Paolo Corti" <pcorti at gmail.com> escribió:
> I would add that also SLD files are synced with the GeoNode database,
> so in case you need to restore styles you should be able to do it.
> p
> On Thu, Apr 14, 2016 at 1:46 AM, Simone Dalmasso
> <simone.dalmasso at gmail.com> wrote:
> > hi Israel,
> > you probably cannot recover geoserver but somehow rebuild it, as all the
> > vector layers are in the db you can connect back a fresh geoserver
> manually
> > creating the store. For raster data check if you have a copy in var www
> > geonode uploaded layer, and you can re upload them.
> > hope it helps
> > 2016-04-14 4:37 GMT+02:00 Israel López <asralf at gmail.com>:
> >> Hi devs, well I'm in trouble... Accidentally delete the directory
> >> geoserver
> >> at tomcat7 webapps,.. In fact, It was deleted the geoserver.war and then
> >> the geoserver directory.
> >> Do you know some way to recover my geoserver???
> >> The databases are ok
> >> I would appreciate any ideas, thanks.
> >> _______________________________________________
> >> geonode-users mailing list
> >> geonode-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
> > Simone
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160419/25c1df3b/attachment.html>
More information about the geonode-users mailing list
