[GeoNode-users] Geonode SRS 3857
Daniel Victoria daniel.victoria at gmail.com
Fri Feb 12 02:39:11 PST 2016
On the topic of the ITRF 2005 (rwanda) projection not being recognized,
I've encountered similar issues when dealing with SIRGAS2000 (Brazil
specific datum). What I figured is that the .prj file generated by ESRI
software does not seem to conform to the standards expected by GeoServer.
So the projection is not recognized. THe solution was to delete the .prj
file and define the projectin using QGis. Could you try that?
However, the funny thing is that the proj2epsg site did recognize the ESRI
.prj file. SO I'm not sure where the problem is. If it's ESRI or GeoServer.
Cheers
Daniel
On Fri, Feb 12, 2016 at 6:53 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> This is strange, as you upload the .prj file geoserver should be able to
> recognise it.
> Try to upload the file directly in geoserver and chek whether the prj is
> correct and geoserver can handle such a projection
> 2016-02-12 9:37 GMT+01:00 Allan Oware <allanoware at gmail.com>:
>> Hi Simone,
>> On the same topic, is it possible for GeoNode/GeoServer/Geoexplorer to
>> support upload/storage/visualization of data which is in a projected
>> coordinate system
>> specific to a country e.g ITRF 2005 (rwanda) ?
>> When I attempt to upload such data in my 2.4 instance, the uploader
>> returns
>> "GeoServer failed to detect the projection for layer [airports]. It
>> doesn't look like EPSG:4326, so backing out the layer."
>> Regards,
>> On Thu, Feb 11, 2016 at 3:34 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Can't reach your server, anyway would be strange if geoserver treats
>>> 900913 requests different from 3857.
>>> @afabiani any hints?
>>> 2016-02-11 10:26 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>>> Hi Simone,
>>>> It’s strange yes… In GeoServer the layers are served in 3857 (native
>>>> and declared) and if I preview the layer directly from GeoServer I can see
>>>> those labels correctly but once loaded into the GeoExplorer Map the tiles
>>>> are requested under 900913, I mean, I’ve tracking them down with fiddler
>>>> and I can’t see anywhere a 3857 parameter.
>>>> If you want to check the layer I’m using you can do it with:
>>>> http://www.geo.euskadi.eus/WMS_NEKAZARITZA?
>>>> LAYER=ADR_DR_TEXT
>>>> Agur bero bat,
>>>> David Alda Fernández de Lezea
>>>> Área de Sistemas de Información Geográfica, Planificación Territorial y
>>>> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
>>>> Arloa.
>>>> dalda at hazi.eus | www.hazi.eus
>>>> T 945 003 240 – M 627 923 170 – F 945 003 290
>>>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
>>>> *********************  LEGE OHARRA   *******************   AVISOLEGAL
>>>> *******************   DISCLAIMER   *****************************
>>>> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
>>>> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
>>>> kontserbatu gabe.
>>>> Este mensaje es personal y confidencial y su uso no autorizado está
>>>> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
>>>> sin reenviarlo ni conservarlo.
>>>> This message is personal and confidential, unauthorised use is legally
>>>> prohibited. If you are not the intended recipient, delete it without
>>>> resending or backing it.
>>>> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
>>>> Enviado el: jueves, 11 de febrero de 2016 10:11
>>>> Para: David Alda Fernandez de Lezea
>>>> CC: geonode-users at lists.osgeo.org
>>>> Asunto: Re: [GeoNode-users] Geonode SRS 3857
>>>> Hi,
>>>> the two srs should be exactly the same. I've loaded many 3857 layers
>>>> without any issue or need to change the geonode code. Also, geonode
>>>> preserves the native projection so in geoserver they are published as 3857
>>>> and geoexplorer just directly load them.
>>>> Not sure why you get deformed labels.
>>>> 2016-02-10 12:54 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>>>> Hi list,
>>>> I need to change the default CRS to EPSG:3857. In theory it's the same
>>>> to EPSG:900913 but when I get a layer in a native 3857 CRS if I load the
>>>> layer into the GeoExplorer the labels and vector contours appear slightly
>>>> deformed.
>>>> I've changed views.py and layers.py but I still get in the map
>>>> SRS=EPSG:900913 requests..
>>>> Where do I have to change the default srs?
>>>> Is there a plan to move from 900913 to 3857?? 900913 seems to be
>>>> obsolete and the official is 3857?
>>>> Thanks,
>>>> Agur bero bat,
>>>> Arloa.
>>>> T 945 003 240 - M 627 923 170 - F 945 003 290
>>>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
>>>> kontserbatu gabe.
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>>> Simone
>> Allan Oware
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160212/071ca51e/attachment-0001.html>
More information about the geonode-users mailing list
