[GeoNode-users] [GeoNode-devel] Pycsw vs Geonetwork
Tom Kralidis tomkralidis at gmail.com
Fri Feb 19 05:20:49 PST 2016
On Fri, Feb 19, 2016 at 7:59 AM, Allan Oware <allanoware at gmail.com> wrote:
> In some cases I've encountered, some users would want a geonode/geoportal
> implementation with more emphasis on the
> metadata catalog than the data itself. For instance, an organisation would
> want to open up its data inventory instead of opening up
> the data. Also, if they already have a running geonetwork instance, pycsw
> will be redundant in such a case.
Good points here.  This is exactly why GeoNode has the ability to swap out
pycsw for an alternate CSW backend, such as GeoNetwork OpenSource, or
deegree, and so on.
Having said this, significant metadata editing improvements are in scope [1].
[1] https://github.com/GeoNode/geonode/issues/2408
> On Fri, Feb 19, 2016 at 2:09 PM, Derek <gamesbook at gmail.com> wrote:
>> Probably because its an official OGC Reference Implementation since 2012 -
>> http://www.opengeospatial.org/resource/products/details/?pid=1325
>> Any reason you'd want to make it Geonetwork?
>> On 18 February 2016 at 23:43, Allan Oware <allanoware at gmail.com> wrote:
>>> Hi,
>>> Am not sure whether this has been mentioned on the list before, starting
>>> Geonode 2.0, why was Pycsw preferred as the default catalogue server instead
>>> of Geonetwork opensource ? I understand one can switch to an alternate csw
>>> backend after installing geonode, but were there issues with geonetwork that
>>> prompted the switch to pycsw ?
>>> Regards.
>>> Allan Oware
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Allan Oware
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-users mailing list
