[GeoNode-users] Errors on layer info after upgrade
Francesco Bartoli xbartolone at gmail.com
Fri Feb 19 12:44:23 PST 2016
Hi Paolo,
it is also possible to override it by passing a java system property like JAVA_OPTS="-DGEOSERVER_DATA_DIR=<somewhere>" to your container’s jvm options of its init script.
Francesco
Il giorno 19/feb/2016, alle ore 16:47, Paolo Corti <pcorti at gmail.com> ha scritto:
> Hi Annalisa
> that is the only setting where you can change the location of the
> GeoServer data directory.
> p
> On Fri, Feb 19, 2016 at 5:05 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
>> I was wondering, there is a place in geonode where setting the
>> Geoserver-data-dir?
>> I've just modified web.xml file in /usr/share/geoserver/WEB-INF
>> 2016-02-18 18:18 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
>>> The layer info page doesn't caused errors on 2.4c1, but the "manage style"
>>> operation caused no result on "load styles".
>>> I don't know what value had sld_url.
>>> I upgrade ubuntu, after having update ppa references. Then I've changed
>>> the geoserver data-dir, from default to my path. At this point I have 73
>>> layers on geoserver and also on geonode, but the errors described above.
>>> Than I run updatelayers, but with no result. I run again updatelayers,
>>> adding some layers, and the new layers have the right value of sld_url and
>>> the layer info page is OK forma the news.
>>> Il 18/feb/2016 03:28 PM, "Paolo Corti" <pcorti at gmail.com> ha scritto:
>>>> Hi Annalisa
>>>> this is strange indeed, because accordingly to what you did the value
>>>> for sld_url shouldn't have changed (unless you run updatelayers on the
>>>> layer), and that value indicates that at
>>>> some point the layer was saved and this generated the error (every
>>>> time the layer is saved the style table is synced with GeoServer).
>>>> Are you sure that this page was not causing error also on 2.4c1?
>>>> cheers
>>>> p
>>>> On Thu, Feb 18, 2016 at 9:19 AM, Annalisa Schiavon
>>>>> Maybe I found the error. In my layers_style table, the field "sld_url"
>>>>> is
>>>>> like:
>>>>> <bound method Style.body_href of <geoserver.style.Style object at
>>>>> 0x7f9a0fda9610>>
>>>>> or
>>>>> http://localhost:8080/geoserver/rest/styles/depuratoripubblici.xml
>>>>> If I change the field to
>>>>> "http://localhost:8080/geoserver/rest/styles/acque_transizione.sld",
>>>>> for
>>>>> example, there's no errors for that layer.
>>>>> I've launched an updatelayers for all my layers, before found this, but
>>>>> it
>>>>> doesn't correct the layer's styles. Is it linked to this issue:
>>>>> https://github.com/GeoNode/geonode/issues/2329 ?
>>>>> However the updatelayers has deleted some layers, I don't know why, and
>>>>> then
>>>>> it has re-created them, correctly.
>>>>> So, now, I have to change manually all "sld_url" values or you have
>>>>> other
>>>>> suggestions?
>>>>> Thanks
>>>>> Annalisa
>>>>> 2016-02-18 14:44 GMT+01:00 Muhammad <mnabiahmad at gmail.com>:
>>>>>> Hi Alessio
>>>>>> See if data in field 'detail_url' from table base_resourcebase are
>>>>>> correct. It should not be empty.
>>>>>> On 02/18/2016 04:11 PM, Alessio Fabiani wrote:
>>>>>> Did you specify the DB PORT on your local_settings.py?
>>>>>> If so, be sure the value is quoted:
>>>>>> "5432"
>>>>>> if you remove the quotes you'll get an error similar to the one on the
>>>>>> logs.
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> GeoServer Professional Services from the experts!
>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A
>>>>>> 55054  Massarosa (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax:     +39 0584 1660272
>>>>>> mob:   +39 333 8128928
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
>>>>>> Il loro
>>>>>> utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>> per le
>>>>>> finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>> messaggio
>>>>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>>>>>> notizia
>>>>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>>>>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>> divulgarlo
>>>>>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>> utilizzarlo per
>>>>>> finalità diverse, costituisce comportamento contrario ai principi
>>>>>> dettati
>>>>>> dal D.Lgs. 196/2003.
>>>>>> The information in this message and/or attachments, is intended solely
>>>>>> for
>>>>>> the attention and use of the named addressee(s) and may be
>>>>>> confidential or
>>>>>> proprietary in nature or covered by the provisions of privacy act
>>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection
>>>>>> Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction,
>>>>>> copying, distribution, or either dissemination, either whole or
>>>>>> partial, is
>>>>>> strictly forbidden except previous formal approval of the named
>>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>> information in this message that has been received in error. The
>>>>>> sender does
>>>>>> not give any warranty or accept liability as the content, accuracy or
>>>>>> completeness of sent messages and accepts no responsibility  for
>>>>>> changes
>>>>>> made after they were sent or for other risks which arise as a result
>>>>>> of
>>>>>> e-mail transmission, viruses, etc.
>>>>>> On Thu, Feb 18, 2016 at 1:47 PM, Annalisa Schiavon
>>>>>>> I have sld styles for all my layers. But on geoserver, the preview
>>>>>>> works
>>>>>>> fine.
>>>>>>> What field on DB I have to check?
>>>>>>> It may be due to the fact that I don't have upload sessions
>>>>>>> associated to
>>>>>>> my layers?
>>>>>>> I usually load layers on postgis, then I create layers in geoserver
>>>>>>> and
>>>>>>> then I throw  geonode updatelayers from console.
>>>>>>> 2016-02-18 13:14 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
>>>>>>>> 2016-02-18 12:54 GMT+01:00 Annalisa Schiavon
>>>>>>>>> Hi all,
>>>>>>>>> I've just upgrade geonode from 2.4c1 to 2.4 stable. No errors
>>>>>>>>> during
>>>>>>>>> installation, no problem to log in geonode and geoserver, but the
>>>>>>>>> layer info
>>>>>>>>> page  gives "Internal Server Error".
>>>>>>>>> It's all ok in maps, on layers list's, but when I click on a
>>>>>>>>> layer, it
>>>>>>>>> gives
>>>>>>>>> internal error.
>>>>>>>> Accoridng to lines 73-74 of erro.log it seems that the script
>>>>>>>> geonode/layers/models.py is unable to make the right url for sld
>>>>>>>> style
>>>>>>>> (index out of range)
>>>>>>>> Do you have custom sld style associated to  the tested layer
>>>>>>>> (rete_balneazione_2015)?
>>>>>>>> Amedeo Fadini
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> best regards
>>>>>> Muhammad Nabi Ahmad
>>>>>> Twitter : mnabiahmad
>>>>>> Blog    : https://scriptndebug.wordpress.com/
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
More information about the geonode-users mailing list
