[GeoNode-users] demo.geonode.org
Paolo Corti
pcorti at gmail.com
Mon Feb 22 10:40:41 PST 2016
Hi Ivo
make sure your browser is using the upgraded version
p
On Mon, Feb 22, 2016 at 9:40 AM, Ivo Santos <ivojfs at gmail.com> wrote:
> geonode collectstatic changed some files:
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/pencil_add.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/map_save.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/arrow_inout.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/palette.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/gxp/src/theme/img/silk/map_save.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/gxp/src/theme/img/silk/map_go.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/default/grid/grid3-hd-btn-2.gif'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/default/grid/caret-down_1a1a1a_14.png'
> Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/gray/panel/tool-sprites-old.gif'
> But it was not enough. I tried to compare
> /var/www/geonode/static/geoexplorer/theme/app/geoexplorer.css and
> https://github.com/GeoNode/django-geoexplorer/blob/master/geoexplorer/static/geoexplorer/theme/app/geoexplorer.css
> and they are very different.
> I have the correct file on
> /usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/geoexplorer.css
> Thank you for your help.
> 2016-02-22 14:28 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> ok, then geonode collectstatic. Sorry, forgot to add this before.
>> 2016-02-22 15:21 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>> Hi Simone,
>>> I am not sure of the previous version of geonode, but it was not from the
>>> stable ppa. It was installed using the spapshots ppa on the last trimester
>>> of 2015. After it, I upgraded to the version on the stable ppa.
>>> Tried a sudo pip install django-geoexplorer --upgrade and it was already
>>> up-to-date... Version: 4.0.5
>>> 2016-02-22 13:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Hi Ivo,
>>>> yes the demo is the 2.4 stable. The white theme for gxp has been
>>>> introduced a while ago. Any chance you upgraded from an older version?
>>>> A $ sudo apt-get install django-geoexplorer might help.
>>>> 2016-02-22 13:03 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>> Hi all,
>>>>> I went to the geonode demo yesterday and I realized that the style
>>>>> (css?) of the layout of geoexplorer is different than the one installed on
>>>>> my server. I do like it a lot.
>>>>> I have the last stable version installed on my server (2.4). Do you
>>>>> know if it is the same version that is on demo.geonode.org?
>>>>> Thank you,
>>>>> Ivo
>>>>> Ivo Santos
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>>> Ivo Santos
>> Simone
> Ivo Santos
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
