[GeoNode-users] demo.geonode.org
Ivo Santos ivojfs at gmail.com
Tue Feb 23 00:48:36 PST 2016
Solved erasing the theme files and running collectstatic again.
Thanks,
Ivo
On Mon, Feb 22, 2016, 18:41 Paolo Corti <pcorti at gmail.com> wrote:
> Hi Ivo
> make sure your browser is using the upgraded version
> p
> On Mon, Feb 22, 2016 at 9:40 AM, Ivo Santos <ivojfs at gmail.com> wrote:
> > geonode collectstatic changed some files:
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/pencil_add.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/map_save.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/arrow_inout.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/img/silk/palette.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/gxp/src/theme/img/silk/map_save.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/gxp/src/theme/img/silk/map_go.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/default/grid/grid3-hd-btn-2.gif'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/default/grid/caret-down_1a1a1a_14.png'
> > Copying
> '/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/externals/ext/resources/images/gray/panel/tool-sprites-old.gif'
> > But it was not enough. I tried to compare
> > /var/www/geonode/static/geoexplorer/theme/app/geoexplorer.css and
> https://github.com/GeoNode/django-geoexplorer/blob/master/geoexplorer/static/geoexplorer/theme/app/geoexplorer.css
> > and they are very different.
> > I have the correct file on
> /usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/theme/app/geoexplorer.css
> > Thank you for your help.
> > 2016-02-22 14:28 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> >> ok, then geonode collectstatic. Sorry, forgot to add this before.
> >> 2016-02-22 15:21 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> >>> Hi Simone,
> >>> I am not sure of the previous version of geonode, but it was not from
> the
> >>> stable ppa. It was installed using the spapshots ppa on the last
> trimester
> >>> of 2015. After it, I upgraded to the version on the stable ppa.
> >>> Tried a sudo pip install django-geoexplorer --upgrade and it was
> already
> >>> up-to-date... Version: 4.0.5
> >>> 2016-02-22 13:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com
> >>>> Hi Ivo,
> >>>> yes the demo is the 2.4 stable. The white theme for gxp has been
> >>>> introduced a while ago. Any chance you upgraded from an older version?
> >>>> A $ sudo apt-get install django-geoexplorer might help.
> >>>> 2016-02-22 13:03 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> >>>>> Hi all,
> >>>>> I went to the geonode demo yesterday and I realized that the style
> >>>>> (css?) of the layout of geoexplorer is different than the one
> installed on
> >>>>> my server. I do like it a lot.
> >>>>> I have the last stable version installed on my server (2.4). Do you
> >>>>> know if it is the same version that is on demo.geonode.org?
> >>>>> Thank you,
> >>>>> Ivo
> >>>>> Ivo Santos
> >>>>> _______________________________________________
> >>>>> geonode-users mailing list
> >>>>> geonode-users at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> >>>> Simone
> >>> Ivo Santos
> >> Simone
> > Ivo Santos
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160223/daea386e/attachment.html>
More information about the geonode-users mailing list
