[GeoNode-users] GeoNODE security settings with remote Geoserver	2.9.1
    Francesco Bartoli
    xbartolone at gmail.com
    Mon Jun 27 05:53:37 PDT 2016
Hi Paul,
The stable version 2.4 is expecting to work well with the GeoServer build for GeoNode at version 2.7.4 [1]. Even the master from github isn’t supporting GS 2.9.x yet. If you want to build it for this latter version then you have to compile that on your own
Francesco
[1] http://build.geonode.org/geoserver/latest/geoserver.war
Il giorno 27/giu/2016, alle ore 14:15, Paul Grambauer <Paul.Grambauer at sunshinecoast.qld.gov.au> ha scritto:
> Hi,
> We are having some issues with viewing layers and maps from a remote geoserver install.  We have changed the the localhost geoserver to another server running Geoserver 2.9.1.
> We have found some GeoNode-GeoServer-ext JAR files (?v2.7) and have installed these on geoserver - all seems OK, and can login to geoserver using user created in GeoNode.
> Our issue is when view layers on the maps, the user is prompted with a GeoNodeCookie authentication error - is there something that we are missing - a configuration somewhere?
> Thanks,
> Paul Grambauer
> P 0448 117 316
> E paul.grambauer at sunshinecoast.qld.gov.au
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
