[GeoNode-users] No route to host
Francesco Bartoli xbartolone at gmail.com
Tue Jun 28 12:04:58 PDT 2016
Did you get geonode from apt-get? Why are you running GS 2.5.1 while GN 2.4 is shipped with 2.7.4?
However the error looks like related to some firewall rule that is blocking your request.
Francesco
Il giorno 28/giu/2016, alle ore 20:26, Israel López <asralf at gmail.com> ha scritto:
> Good day dear devs, I'm having troubles with upload
> a shape file in a production environment, the apache
> error.log is:
> [Tue Jun 28 13:13:32.341541 2016] [:error] [pid 9762:tid 139855292634880] [Errno 113] No route to host
> [Tue Jun 28 13:13:32.341647 2016] [:error] [pid 9762:tid 139855292634880] Traceback (most recent call last):
> [Tue Jun 28 13:13:32.341656 2016] [:error] [pid 9762:tid 139855292634880]   File "/var/www/html/idegeo24/geonode/layers/views.py", line 166, in layer_upload
> [Tue Jun 28 13:13:32.341664 2016] [:error] [pid 9762:tid 139855292634880]     title=form.cleaned_data["layer_title"],
> [Tue Jun 28 13:13:32.341670 2016] [:error] [pid 9762:tid 139855292634880]   File "/var/www/html/idegeo24/geonode/layers/utils.py", line 470, in file_upload
> [Tue Jun 28 13:13:32.341677 2016] [:error] [pid 9762:tid 139855292634880]     defaults=defaults
> [Tue Jun 28 13:13:32.341683 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 154, in get_or_create
> [Tue Jun 28 13:13:32.341690 2016] [:error] [pid 9762:tid 139855292634880]     return self.get_queryset().get_or_create(**kwargs)
> [Tue Jun 28 13:13:32.341696 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py", line 341, in get_or_create
> [Tue Jun 28 13:13:32.341703 2016] [:error] [pid 9762:tid 139855292634880]     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> [Tue Jun 28 13:13:32.341709 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 383, in get_or_create
> [Tue Jun 28 13:13:32.341716 2016] [:error] [pid 9762:tid 139855292634880]     obj.save(force_insert=True, using=self.db)
> [Tue Jun 28 13:13:32.341722 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line 90, in save
> [Tue Jun 28 13:13:32.341729 2016] [:error] [pid 9762:tid 139855292634880]     return super(PolymorphicModel, self).save(*args, **kwargs)
> [Tue Jun 28 13:13:32.341735 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in save
> [Tue Jun 28 13:13:32.341741 2016] [:error] [pid 9762:tid 139855292634880]     force_update=force_update, update_fields=update_fields)
> [Tue Jun 28 13:13:32.341748 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 569, in save_base
> [Tue Jun 28 13:13:32.341754 2016] [:error] [pid 9762:tid 139855292634880]     update_fields=update_fields)
> [Tue Jun 28 13:13:32.341760 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185, in send
> [Tue Jun 28 13:13:32.341767 2016] [:error] [pid 9762:tid 139855292634880]     response = receiver(signal=self, sender=sender, **named)
> [Tue Jun 28 13:13:32.341773 2016] [:error] [pid 9762:tid 139855292634880]   File "/var/www/html/idegeo24/geonode/geoserver/signals.py", line 74, in geoserver_pre_save
> [Tue Jun 28 13:13:32.341779 2016] [:error] [pid 9762:tid 139855292634880]     charset=instance.charset)
> [Tue Jun 28 13:13:32.341785 2016] [:error] [pid 9762:tid 139855292634880]   File "/var/www/html/idegeo24/geonode/geoserver/helpers.py", line 1190, in geoserver_upload
> [Tue Jun 28 13:13:32.341807 2016] [:error] [pid 9762:tid 139855292634880]     sld = get_sld_for(publishing)
> [Tue Jun 28 13:13:32.341813 2016] [:error] [pid 9762:tid 139855292634880]   File "/var/www/html/idegeo24/geonode/geoserver/helpers.py", line 189, in get_sld_for
> [Tue Jun 28 13:13:32.341818 2016] [:error] [pid 9762:tid 139855292634880]     name = layer.default_style.name if layer.default_style is not None else "point"
> [Tue Jun 28 13:13:32.341824 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/geoserver/layer.py", line 103, in _get_default_style
> [Tue Jun 28 13:13:32.341830 2016] [:error] [pid 9762:tid 139855292634880]     return self._resolve_style(element) if element is not None else None
> [Tue Jun 28 13:13:32.341835 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/geoserver/layer.py", line 111, in _resolve_style
> [Tue Jun 28 13:13:32.341841 2016] [:error] [pid 9762:tid 139855292634880]     return self.catalog.get_style_by_url(style_workspace_url)
> [Tue Jun 28 13:13:32.341846 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/geoserver/catalog.py", line 798, in get_style_by_url
> [Tue Jun 28 13:13:32.341851 2016] [:error] [pid 9762:tid 139855292634880]     dom = self.get_xml(style_workspace_url)
> [Tue Jun 28 13:13:32.341857 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/local/lib/python2.7/dist-packages/geoserver/catalog.py", line 211, in get_xml
> [Tue Jun 28 13:13:32.341862 2016] [:error] [pid 9762:tid 139855292634880]     response, content = self.http.request(rest_url)
> [Tue Jun 28 13:13:32.341867 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1569, in request
> [Tue Jun 28 13:13:32.341873 2016] [:error] [pid 9762:tid 139855292634880]     (response, content) = self._request(conn, authority, uri, request_uri, method, body, headers, redirections, cach$
> [Tue Jun 28 13:13:32.341879 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1316, in _request
> [Tue Jun 28 13:13:32.341885 2016] [:error] [pid 9762:tid 139855292634880]     (response, content) = self._conn_request(conn, request_uri, method, body, headers)
> [Tue Jun 28 13:13:32.341890 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1289, in _conn_request
> [Tue Jun 28 13:13:32.341895 2016] [:error] [pid 9762:tid 139855292634880]     conn.connect()
> [Tue Jun 28 13:13:32.341901 2016] [:error] [pid 9762:tid 139855292634880]   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 912, in connect
> [Tue Jun 28 13:13:32.341906 2016] [:error] [pid 9762:tid 139855292634880]     raise socket.error, msg
> [Tue Jun 28 13:13:32.341911 2016] [:error] [pid 9762:tid 139855292634880] error: [Errno 113] No route to host
> I'm running Geoserver 2.5.1 with geonode 2.4, I don't know if this could be the trouble.
> Any advice is welcome.
> Thank you in advance.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/3ee3f661/attachment.html>
More information about the geonode-users mailing list
