[GeoNode-users] A bug detected by me and others when zooming our project outcome maps
Ariel Nunez ingenieroariel at gmail.com
Mon May 9 03:45:11 PDT 2016
Everton,
Since the issue is cause by configuration of Bing as a sources in
/etc/geonode/local_settings.py, it is possible to experience the problem
even when upgrading to a latter version (if you use the settings from the
older version and chose to keep it during the upgrade).
Do you need Bing layers? If not, you can solve the problem in two minutes
by editing /etc/geonode/local_settings.py to remove the bing source and
reload apache.
-a
On Mon, May 9, 2016 at 5:41 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, if the issue is the one due to the bing map issue than the solution is
> the one in the thread. Beware that eliminating bing from the sources only
> solves for new maps, but for existing maps you will have to issue the
> commands that you see in the thread.
> 2016-05-09 12:34 GMT+02:00 Everton Valiati Hemerly <
> E.ValiatiHemerly at tudelft.nl>:
>> Dear Simone,
>> Thank you for your response but unfortunately this is the feedback I got
>> from our ITC manager about the Geonode issue: "This is exactly what I
>> tried in February and it is installed on the system since. It doesn't solve
>> the problem."
>> I hope you find soon the source of the problem. Thank you all for the
>> help!
>> Best
>> *Dr. Everton Valiati Hemerly*, Researcher
>> *T**U **Delft** /Civil Engineering & Geosciences, *Geoscience and Remote
>> Sensing
>> Room 2.120, Stevinweg 1, 2628 CN, Delft, The Netherlands
>> M  +31 (10) 619797325
>> E   e.valiatihemerly at tudelft.nl
>> W  www.grs.citg.tudelft.nl
>> *From:* Erwin de Beus
>> *Sent:* Monday, May 09, 2016 8:59 AM
>> *To:* Everton Valiati Hemerly
>> *Cc:* Ramses Molijn - CITG; Lorenzo Iannini - CITG
>> *Subject:* Re: [GeoNode-users] A bug detected by me and others when
>> Dear Everton,
>> I’m afraid you are running around in circles. Please have a look at our
>> email conversation on March the 7th. This is exactly what I tried in
>> February and it is installed on the system since. It doesn't solve the
>> problem.
>> Best regards,
>> Erwin
>> Op 6 mei 2016, om 20:13 heeft Everton Valiati Hemerly <
>> <http://redir.aspx?REF=Hwp19K-OKaTHpdHPV5Uil8ucpefQFujW7OwOlqf6W6Om-V3583fTCAFtYWlsdG86RS5WYWxpYXRpSGVtZXJseUB0dWRlbGZ0Lm5s>>
>> het volgende geschreven:
>> Dear Erwin,
>> I have forwarded your email do the Geonode developers group and I
>> received the the response below from them. They say we should try:
>> http://lists.osgeo.org/pipermail/geonode-users/2015-October/000850.html
>> <http://redir.aspx?REF=VjpElYmN5qkTwtgwnE8N8MqYEbelGnhl1UCyztQOUhem-V3583fTCAFodHRwczovL3dlYm1haWwudHVkZWxmdC5ubC9vd2EvcmVkaXIuYXNweD9SRUY9R3NDZHJ5WUc3OHFrcjI2b3c4clJlNlZQcWt6aHdTWjlPYTk2T0ZpV2NCd0ZzSFE3MlhYVENBRm9kSFJ3T2k4dmJHbHpkSE11YjNOblpXOHViM0puTDNCcGNHVnliV0ZwYkM5blpXOXViMlJsTFhWelpYSnpMekl3TVRVdFQyTjBiMkpsY2k4d01EQTROVEF1YUhSdGJBLi4.>
>> Please, could you see if it can help us? Many thanks again.
>> Regards.
>> Sensing
>> <http://redir.aspx?REF=GtEOY8ybKi_5qilGEsiq0rjdf-g4-i7oPjG3gCvg0zum-V3583fTCAFtYWlsdG86ZS52YWxpYXRpaGVtZXJseUB0dWRlbGZ0Lm5s>
>> <http://redir.aspx?REF=wyjLmH2g3f4uoHPhVvgflR3_vzgRYRVpI0_gLsTjFSSm-V3583fTCAFodHRwOi8vd3d3Lmdycy5jaXRnLnR1ZGVsZnQubmwv>
>> *From:* Simone Dalmasso [simone.dalmasso at gmail.com
>> <http://redir.aspx?REF=i0wZpbKrRa8dd0RnhdIoSDgUUhoQ97-tM7xbqH33x8im-V3583fTCAFtYWlsdG86c2ltb25lLmRhbG1hc3NvQGdtYWlsLmNvbQ..>
>> *Sent:* Friday, May 06, 2016 8:05 PM
>> *Cc:* geonode-users at lists.osgeo.org
>> <http://redir.aspx?REF=XwR4dnk8GxYB1g4m7yABKcwpTMkI2QgR0WtfHYSd18em-V3583fTCAFtYWlsdG86Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc.>
>> Hi this thread should help you to fix it
>> <http://UrlBlockedError.aspx>
>> hope it helps
>> 2016-05-06 17:28 GMT+02:00 Everton Valiati Hemerly <
>> E.ValiatiHemerly at tudelft.nl <http://UrlBlockedError.aspx>>:
>>> Dear Geonode Developers,
>>> I have created this map to help one to disseminate their project
>>> outcomes; please see it:
>>>  http://be-basic.grs.tudelft.nl/maps/313/view
>>> But I still have a important issue which comes from a bug detected by
>>> me and others when zooming maps.  As you can read below from my ITC
>>> supporter, "This is caused by an incompatibility with Google Maps and/or
>>> Bing maps and needs to be fixed by the developers of Geonode in an upcoming
>>> release. But at the moment there is no such thing."
>>> So, I would like to ask you, is it true what he is saying? Should I wait
>>> for the next version?! I know You just released the 2.4.0 !
>>> Thank you very much and We are looking forward to fix this issue very
>>> soon.
>>> (Below the ITC tecnician response)
>>>  Hi Everton,
>>> We just had a look at the be-basic.grs.tudelft.nl
>>> <http://UrlBlockedError.aspx> server and as far as I can tell  it is
>>> running geonode 2.4.0 + final patch. This is the latest release that is
>>> available from Geonode.org
>>> <http://redir.aspx?REF=7cY0I312aJq4cVZsLyKTLfix9Ze-hdPVv5avF1zOxYKm-V3583fTCAFodHRwOi8vZ2Vvbm9kZS5vcmcv>
>>> root at be-basic:~# dpkg -s geonode
>>> Package: geonode
>>> Status: install ok installed
>>> Priority: extra
>>> Section: science
>>> Installed-Size: 4370
>>> Maintainer: Ariel Nunez <ingenieroariel at gmail.com>
>>> Architecture: all
>>> Version: 2.4.0+thefinal0
>>> Possibly, the confusion comes from a bug detected by Everton when
>>> zooming maps. This is caused by an incompatibility with Google Maps and/or
>>> Best regards,
>>> Erwin
>>> (finished)
>>> Best regards.
>>> Remote Sensing
>>> E   e.valiatihemerly at tudelft.nl <http://UrlBlockedError.aspx>
>>> W  www.grs.citg.tudelft.nl <http://UrlBlockedError.aspx>
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org <http://UrlBlockedError.aspx>
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160509/b1223462/attachment.html>
More information about the geonode-users mailing list
