[GeoNode-users] How to increase the size of GeoExplorer component in Layers section?
Francesco Bartoli xbartolone at gmail.com
Tue May 24 11:20:48 PDT 2016
Hi Benjamin,
you can find more information on gxp API and the options for the gxp.Viewer class here [1]. Basically you could create your own “viewer” [2] with the use of suite-sdk [3], configure it with your custom configurations and then ship into GeoNode by replacing the default geoexplorer mentioned by Simone.
Hope this helps you further.
Francesco
[1] http://suite.opengeo.org/docs/latest/sdk-api/lib/widgets/Viewer.html
[2] http://suite.opengeo.org/docs/latest/webapps/gxp/basic/index.html
[3] http://suite.opengeo.org/docs/latest/webapps/install.html
Il giorno 24/mag/2016, alle ore 12:11, Benjamin Ducke <benducke at fastmail.fm> ha scritto:
> On 24/05/16 09:09, Simone Dalmasso wrote:
>> The portalConfig is part of the Boundless gxp (GeoNode ships it as it is
>> more or less) so you may find docs
>> there. http://suite.opengeo.org/opengeo-docs/geoexplorer/
>> hope this helps
> Unfortunately, these pages are too vague
> and don't provide enough detail. I have
> filed an "issue" with the OpenGeoSuite
> guys. As soon as I have something like a
> comprehensive list of "portalConfig"
> settings, I will share it on this list.
> Thanks and best,
> Ben
>> 2016-05-24 8:55 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
>> <mailto:benducke at fastmail.fm>>:
>>    Hi Simone,
>>    Thanks for you advice.
>>    I also suspect that there is something going
>>    wrong with the Apache config or browser cache.
>>    I am a bit frustrated that I cannot seem to
>>    dig up any documentation on "portalConfig",
>>    because I think that is a powerful configuration
>>    mechanism which could provide a lot of the
>>    features I am looking for (incl. the layer tree
>>    mentioned in my other email).
>>    I will investigate this further and then report
>>    back to this list once I figured it out.
>>    Cheers,
>>    Ben
>>    On 24/05/16 07:52, Simone Dalmasso wrote:
>>> Hi, that "height" is the correct place. No need to restart apache
>>> because is just a template. If the change id not take effect then
>>    could
>>> it be that your template is not the one served by apache? if you
>>    inspect
>>> the page can you see your height in there?
>>> 2016-05-23 19:38 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
>>> <mailto:benducke at fastmail.fm <mailto:benducke at fastmail.fm>>>:
>>>    Thanks for the pointer.
>>>    I assume you refer to this config object:
>>>      portalConfig: {
>>>                        renderTo: "preview_map",
>>>                        height: 400
>>>    I have changed "height" and restarted Apache but no effect.
>>>    Do I have to add something to "portalConfig"?
>>>    Actually, I have not been able to find any documentation on
>>>    the possible contents of "portalConfig". Do you have a URL
>>>    for the official docs?
>>>    Thanks,
>>>    Ben
>>>    Benjamin Ducke
>>>    {*} Geospatial Consultant
>>>    {*} GIS Developer
>>>      benducke AT fastmail.fm <http://fastmail.fm>
>>>    On Mon, May 23, 2016, at 18:34, Jeffrey Johnson wrote:
>>     https://github.com/GeoNode/geonode/blob/master/geonode/layers/templates/layers/layer_geoext_map.html
>>>> On Mon, May 23, 2016 at 9:29 AM, Benjamin Ducke
>>>    <benducke at fastmail.fm <mailto:benducke at fastmail.fm>
>>>> wrote:
>>>>> Hi All --
>>>>> Is there an easy way to increase the size of the embedded
>>>>> GeoExplorer layer viewer?
>>>>> I suppose it must be done in some template, but I cannot
>>>>> seem to find the right one.
>>>>> Any hints much appreciated.
>>>>> Best,
>>>>> Ben
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>    <mailto:geonode-users at lists.osgeo.org>
>>    <mailto:geonode-users at lists.osgeo.org>>
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>>    Dr. Benjamin Ducke
>>    {*} GIS Developer
>>    Spatial technology for the masses, not the classes:
>>    experience free and open source GIS at http://gvsigce.org
>>    geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> Simone
> Dr. Benjamin Ducke
> {*} GIS Developer
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160524/cfe9b1ea/attachment-0001.html>
More information about the geonode-users mailing list
