[GeoNode-users] Error when saving style from gxp
Amedeo Fadini amefad at gmail.com
Tue Nov 22 00:44:53 PST 2016
Hi everybody,
I'm using Geonode 2.4 insatlled via ppa on Ubuntu server.
I usually publish my layers in geoserver (most of them are sql views
from a Postgis Database that aggregate data from other Mysql db using
foreign tables) and so I prepare also the styles in geoserver and then
synchronize with  geonode -updatelayers command.
I need to add the same layer to a map two or more times, with
different styles: when I try to modify the style from the map editor
in geoexplorer it raise an error and  the style is not saved.
Apache error Log attached below
If I clone the style it raise an error "forbidden" (Cannot delete
style associated with an other layer) but at the ends the new style is
saved.
Any clue?
thanks
Amedeo Fadini
 [Tue Nov 22 09:28:42.948952 2016] [:error] [pid 6020] Internal Server
Error: /gs/rest/styles/point.xml
[Tue Nov 22 09:28:42.949015 2016] [:error] [pid 6020] Traceback (most
recent call last):
[Tue Nov 22 09:28:42.949022 2016] [:error] [pid 6020]   File
"/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line
112, in get_response
[Tue Nov 22 09:28:42.949028 2016] [:error] [pid 6020]     response =
wrapped_callback(request, *callback_args, **callback_kwargs)
[Tue Nov 22 09:28:42.949032 2016] [:error] [pid 6020]   File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/views.py",
line 339, in geoserver_rest_proxy
[Tue Nov 22 09:28:42.949037 2016] [:error] [pid 6020]
style_update(request, url)
[Tue Nov 22 09:28:42.949043 2016] [:error] [pid 6020]   File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py",
line 1520, in style_update
[Tue Nov 22 09:28:42.949049 2016] [:error] [pid 6020]     layer.save()
[Tue Nov 22 09:28:42.949057 2016] [:error] [pid 6020]   File
"/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
line 90, in save
[Tue Nov 22 09:28:42.949063 2016] [:error] [pid 6020]     return
super(PolymorphicModel, self).save(*args, **kwargs)
[Tue Nov 22 09:28:42.949067 2016] [:error] [pid 6020]   File
"/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 545,
in save
[Tue Nov 22 09:28:42.949072 2016] [:error] [pid 6020]
force_update=force_update, update_fields=update_fields)
[Tue Nov 22 09:28:42.949077 2016] [:error] [pid 6020]   File
"/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 569,
in save_base
[Tue Nov 22 09:28:42.949082 2016] [:error] [pid 6020]
[Tue Nov 22 09:28:42.949088 2016] [:error] [pid 6020]   File
"/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line
185, in send
[Tue Nov 22 09:28:42.949101 2016] [:error] [pid 6020]     response =
receiver(signal=self, sender=sender, **named)
[Tue Nov 22 09:28:42.949107 2016] [:error] [pid 6020]   File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py",
line 88, in geoserver_pre_save
[Tue Nov 22 09:28:42.949112 2016] [:error] [pid 6020]
gs_resource.title = instance.title
[Tue Nov 22 09:28:42.949117 2016] [:error] [pid 6020] AttributeError:
'NoneType' object has no attribute 'title'
More information about the geonode-users mailing list
