[GeoNode-users] Backup problem
Ana Boljevic ana.boljevic at cedis.me
Sun Aug 27 23:10:52 PDT 2017
Thanks for the answer.
We have installed the latest version - 2.6.2.
Things we have changed after the installation:
-defined proxy (GeoNode is behind corporate proxy server)
Changed default values of:
-Java Memory Usage (
in /etc/default/tomcat7 changed memory 2048 -> 6144 and 128 -> 512
,,JAVA_OPTS="-Djava.awt.headless=true -Xms6144m -Xmx6144m -XX:+UseParallelOldGC -XX:+UseParallelGC -XX:NewRatio=2 -XX:+AggressiveOpts -Xrs -XX:PerfDataSamplingInterval=500 -XX:MaxPermSize=512m"
-JVM Version
-Native JAI (set to true)
-Native JAI ImageIO (set to true)
-enabled Tile Caching
what You can see in screenshot I send as attachment.
Do You have any idea what is happening? Thanks in advance.
Regards,
Ana Boljević
From: Alessio Fabiani [alessio.fabiani at geo-solutions.it]
Sent: Friday, August 25, 2017 10:02 AM
To: Ana Boljevic
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Backup problem
Which version of GeoNode? Recently some fixes to the backup script have been pushed on latest GeoNode versions.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Mon, Aug 21, 2017 at 8:42 AM, Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Dear GeoNode community,
We have user installation geonode on Ubuntu 16.04 server (standard deployment, not developement). For some reason, backup from command line is not working. I have to enter password for every layer with output "pg_dump: No matching tables were found". If you give as any hint, idea or help, we would be thankful.
geonode at gis:~$ sudo geonode backup --backup-dir=/tmp
Before proceeding with the Backup, please ensure that:
 1. The backend (DB or whatever) is accessible and you have rights
 2. The GeoServer is up and running and reachable from this machine
You want to proceed? [n]|y: y
Dumping 'GeoServer Catalog [http://10.0.0.112/geoserver/]' into '/tmp/2017-08-21_011848<tel:011%20848>/geoserver_catalog.zip'.
STARTED - 1/9
COMPLETED - 9/9
Dumped GeoServer Uploaded Data from '/opt/gs_data_dir/data/geonode'.
Dumping GeoServer Vectorial Data : novi_DV_35_kV_NiksicTrebjesa
Password:
Dumping GeoServer Vectorial Data : novi_DV_35kV_Podgor_Utrg
Password:
Dumping GeoServer Vectorial Data : novi_novo_selo_10
Password:
Dumping GeoServer Vectorial Data : novi_DV_110_kV_Virpazar___Bar
Password:
Dumping GeoServer Vectorial Data : topology
Password:
Dumping GeoServer Vectorial Data : layer
Password:
[1]+  Stopped                 sudo geonode backup --backup-dir=/tmp
Regards,
Ana
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170828/f4a374f0/attachment-0001.html>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170828/f4a374f0/attachment-0001.png>
More information about the geonode-users mailing list
