[GeoNode-users] alias and Freemarker template
Annalisa Schiavon annalisa.schiavon at gmail.com
Mon Dec 4 00:19:35 PST 2017
Yes, I saw it. But I was looking for a method to retrieve these
descriptions in the GetFeatures function. It's too long insert many
descriptions here and than in the content.ftl again, with many attributes.
Thanks anyway
Annalisa
2017-12-01 15:00 GMT+01:00 Ariel Neri <ariel.neriw at gmail.com>:
> Hi Annalisa, Maybe you alredy saw this, but just in case... there´s also
> the option to add descriptions of each atribute in the metadata info. These
> descriptions are shown in the atribute tab of the layer description in the
> portal.
> [image: Imagen integrada 2]
> 2017-12-01 10:36 GMT-03:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>
>> Thanks Ariel.
>> But more than alias I had some descriptions, sometimes very long. I tried
>> to shorten them, but in some cases it's difficult.
>> I don't like use names too long as postgresql alias.
>> Finally I choose to upload some documents (I already had PDF with long
>> descriptions), to link them to the layers and also in content.ftl, so if
>> someone do the getFeatures but doesn't understand attribute's names, can
>> dowload a pdf with long descriptions.
>> Maybe It's intricate, but I've no other ideas and time!
>> Annalisa
>> 2017-11-30 13:55 GMT+01:00 Ariel Neri <ariel.neriw at gmail.com>:
>>> Hi Annalisa. I did it creating "views" in Postgresql. Since our original
>>> layers are huge, I load the original layer to "geonode_data" DB and created
>>> diferent views with reduced atributes and alias that anyone can understand.
>>> Here´s an example:
>>> [image: Imagen integrada 1]
>>> Then just publish the view in geoserver
>>> Hope it helps.
>>> Ariel
>>> 2017-11-30 9:27 GMT-03:00 Annalisa Schiavon <annalisa.schiavon at gmail.com
>>>> Hi all,
>>>> I'm using freemarker template, getting names and values of features in
>>>> this way (for example):
>>>>    <#list features as feature>
>>>>      <li>
>>>>        <ul>
>>>>          <#list feature.attributes as attribute>
>>>>            <#if !attribute.isGeometry>
>>>>              <li><b>${attribute.name}</b>: ${attribute.value}</li>
>>>>            </#if>
>>>>         </#list>
>>>>       </ul>
>>>>     </li>
>>>>     <hr>
>>>>   </#list>
>>>> There is a way to use "alias" attribute names?
>>>> If I define some alias or descriptions for attributes in geonode
>>>> metadata layers, they can be used?
>>>> There is a way to define alias in geoserver or in Postgresql (my layers
>>>> are all in DB Postgresql) that can be recalled in content.ftl files?
>>>> Tipically I set some text directly in content.ftl files, but now I've
>>>> layers with many fields and it would be better enter alias for attributes
>>>> once, maybe in the attribute tabs of the layer in Geonode!
>>>> Thanks
>>>> Annalisa
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171204/257998b6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171204/257998b6/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171204/257998b6/attachment-0003.png>
More information about the geonode-users mailing list
