[GeoNode-users] Serving a GeoServer Layer group through GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Dec 20 00:51:03 PST 2017
At the current status I guess the best option is to import them as part of
a "Remote Service" i.e. a WMS cascade.
This feature currently is not very stable and usable on GeoNode, but
improvements are almost ready to be merged by following this GNIP
https://github.com/GeoNode/geonode/issues/3517
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Dec 18, 2017 at 5:39 PM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> I'm serving several large rasters in GeoNode, which I loaded into
> GeoServer and registered using the command 'geonode updatelayers'.
> I now want to group those layers into a 'national' one and I did this
> using GeoServer Layer Group function. However, when I run 'geonode
> updatelayers', the Layer Group is not identified.
> Is it possible to serve Layer Groups through GeoNode? Or should I create a
> map? In the end, I'd like to have one WMS service providing 5 layers that
> make up a national mosaic.
> Cheers
> Daniel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/65794263/attachment-0001.html>
More information about the geonode-users mailing list
