[GeoNode-users] manage.py migrate error
    Paul Knight
    PaulKnight at redcross.org.uk
    Mon Feb 20 07:52:28 PST 2017
I wonder if anyone can assist with an error that I am getting when working through the setup steps of the 'customise the look and feel' section (http://docs.geonode.org/en/latest/tutorials/admin/customize_lookfeel/customize/setup_admin.html).
When running
$ python manage.py migrate
I get the following ImportError message:
  File "manage.py", line 11, in <module>
    execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 328, in execute
    django.setup()
  File "/usr/local/lib/python2.7/dist-packages/django/__init__.py", line 18, in setup
    apps.populate(settings.INSTALLED_APPS)
  File "/usr/local/lib/python2.7/dist-packages/django/apps/registry.py", line 108, in populate
    app_config.import_models(all_models)
  File "/usr/local/lib/python2.7/dist-packages/django/apps/config.py", line 198, in import_models
    self.models_module = import_module(models_module_name)
  File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
    __import__(name)
  File "/home/geonode/geonode/geonode/base/models.py", line 22, in <module>
    from polymorphic import PolymorphicModel, PolymorphicManager
ImportError: cannot import name PolymorphicModel
I have installed Geonode using the full installation on Ubuntu version 14.04
If anyone could help it would be greatly appreciated!
Paul
	This email is for the intended recipient only. It may contain information that is privileged, confidential and/or subject to copyright. If you are not the intended recipient, please delete this email and any attachments immediately. You may not present this message or any part of it to another party without consent from the sender.
Although the British Red Cross has taken steps to ensure this email and any attachments are virus-free, we do not accept any responsibility for viruses, or for inaccurate or incomplete information or failure to deliver information. It is your responsibility to scan the email and any attachments to ensure they are virus-free.
The British Red Cross may monitor the content of emails sent or received by its employees.
The British Red Cross Society, incorporated by Royal Charter 1908, is a charity registered in England and Wales (220949), Scotland (SC037738) and Isle of Man (0752).
The red cross emblem is a protective symbol, the use of which is restricted by international and national law. It may not be reproduced without prior authorisation. For more information, about the emblem, please go to www.redcross.org.uk/About-us/Who-we-are/The-international-Movement/The-emblem.
If you need to contact the British Red Cross, please go to www.redcross.org.uk/About-us/Contact-and-help/Contact-us and select the best option for you.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170220/a09a2cc1/attachment.html>
More information about the geonode-users
