[GeoNode-users] Extend autocomplete-light with new fields
Simone Dalmasso simone.dalmasso at gmail.com
Wed Feb 22 11:53:26 PST 2017
yeah, you have to keep the ResourceBaseAutocomplete otherwise geonode will
break.
You have to add your own and it should already do what you need without
need to hack into the request.
Hope this helps
2017-02-22 15:01 GMT+01:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Sorry Simone,
> I cannot see the forest because of trees.
> The 404 is because you the original one must stay, you should add your own.
> Do you mean a new resourceBase model? or a new autocomplete register
> Instance?
> This is where I´m getting confused as the text_search_input from layers
> page is filtering against
> resourceBase model. AUTOCOMPLETE_URL_RESOURCEBASE = '/autocomplete/
> ResourceBaseAutocomplete/
> which is what I need but simple with more fields than title (abstract +
> puropose).
> search_fields=*[‘title‘,’abstract’,’purpose'],*
> I don't understand why you have to modify the request, in autocomplete all
> is done in a 'magical' way and if you register your own and add the correct
> name in the relevant template then it'll just work.
> I think that´s the key point I´m asking for. How can I tell autocomplete
> to *search* against title, abstract and purpose
> but only *return* fields where the user input is found? It´s this magic
> that is unclear to me.
> To not steal your time, maybe you know of a fork where something like this
> has been done before?
> A code snipptes would help to shorten this and get it running.
> all the best,
> toni
> Am 22.02.2017 um 14:07 schrieb Simone Dalmasso <simone.dalmasso at gmail.com
> 2017-02-22 13:56 GMT+01:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>> Dear Simone,
>> thanks for your fast reply!
>> correct name, see https://github.com/GeoNode/geonode/blob/master/geonode/
>> templates/base.html#L296.
>> I think this template is for the top search, right? I´m working on the
>> left side menu which should be here:
>> https://github.com/GeoNode/geonode/blob/2.4.x/geonode/static
>> /geonode/js/search/search.js#L366
>> Why I´m puzzled is, why do I already get a 404 when changing register as
>> the DAL documentation suggests:
>> FROM:
>> autocomplete_light.register(ResourceBase,
>>> autocomplete_js_attributes={'placeholder': 'Resource name..', },)
>> TO:
>> class CustomResource(autocomplete_light.AutocompleteModelBase):
>>>     search_fields = ['title', ‚abstract‘,’purpose']
>>>     model = ResourceBase
>>> autocomplete_light.register(CustomResource)
>> And if this works how would I get access to *user request q *and the *choices
>> coming from my model* to overwrite the
>> http response. Sorry for asking again but even if DAL says it´s build for
>> easy use it has so many options that it´s
>> hard for me to find a start.
>> thanks!
>> toni
>> Am 22.02.2017 um 13:46 schrieb Simone Dalmasso <simone.dalmasso at gmail.com
>> Hi, definitely the second way is the one to go with. You can see what
>> there's already in geonode and make your own https://github.com/GeoNode
>> /geonode/blob/master/geonode/base/autocomplete_light_registry.py and
>> call it from the template using the correct name, see
>> https://github.com/GeoNode/geonode/blob/master/geonode/templ
>>  hope this helps
>> 2017-02-22 13:26 GMT+01:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de
>>> Hi together,
>>> this might be an easy one. In geonode 2.4 I have extended autocomplete
>>> registry to search in more fields
>>> on layers left side title-search-input.
>>> https://github.com/GeoNode/geonode/blob/2.4.x/geonode/base/a
>>> then changed the base model to return abstract and purpose content as
>>> well:
>>> https://github.com/GeoNode/geonode/blob/2.4.x/geonode/base/m
>>> odels.py#L342
>>>     def __unicode__(self):
>>>         return self.title + ’,’ + self.abstract + ’,’ + self.purpose
>>> The result is a user can search f.e. for ‚dog‘ and autocomplete shows
>>> choices like:
>>> *Dog Title, Dogs Heaven, the purpose is sleep*
>>> *Dogs world, Dogs Hell, the purpose is eat*
>>> All that is missing is that I do not want to show a field when the
>>> search term is not
>>> found in it. F.e. if purpose does not has ‚dog‘ autoselect should not
>>> show it.
>>> *Dog Title, Dogs Heaven*
>>> From the documentation of DAL I assumed that the way to go is to
>>> create/register a subclass like:
>>> and override the httpResponse method. Unfortunately this basic step
>>> already ends in a 404.
>>> Maybe one could bring me on the right track how to achieve filtering the
>>> return.
>>> Thanks,
>>> Toni
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170222/679c717e/attachment.html>
More information about the geonode-users mailing list
