[GeoNode-users] query about the size limit of uploading the documents
Rasika Chinchwade rasikachinchwade31 at gmail.com
Fri Feb 24 01:24:59 PST 2017
yup sure.
Thank you
On Fri, Feb 24, 2017 at 2:51 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi,
> 1) of course you can always hack the geonode code to make it working. The
> geonode.documents app is the place.
> 2) I'm not very confident in extending geoexplorer so cannot help you very
> much in this sorry.
> ps please always write to the list as other may benefit from the response.
> Best
> 2017-02-24 9:49 GMT+01:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>
>> Thank you so much for your quick response.
>> I have following doubts in geonode:
>> 1.   So there is no other way to try  anything  by adding some line or
>> something  .Because this the task in my project I have to find a solution .
>> 2.  in GeoExplorer of geonode I want to add a search box to mark out
>> locations as google maps do. But my .js file where all map tools like
>> map,print,identify etc are defined is also not updating the changes I made
>> to it.I want a search box for geocoading there.
>> Thank you so much
>> On Fri, Feb 24, 2017 at 1:32 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> I noticed that the MAX_DOCUMENT_SIZE is no longer used. Not sure why,
>>> though this means that is not possible to limit the size at the moment.
>>> 2017-02-24 7:06 GMT+01:00 Rasika Chinchwade <
>>> rasikachinchwade31 at gmail.com>:
>>>> hello all,
>>>> I want to know how to update the size limit of  document .
>>>> I got the code in settings.py file of geonode.
>>>> MAX_DOCUMENT_SIZE = 2
>>>> I changed it by reducing to 1 .But it is not working actually.It is
>>>> actually accepting the size greater than the specfied size limit.
>>>> Also I want to give only some users the specified size limit while they
>>>> are using geonode. How I can do it? In which table this info is getting
>>>> stored about user and allowed size limit to him or her.
>>>> Thank you
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170224/36d74b53/attachment.html>
More information about the geonode-users mailing list
