[GeoNode-users] Updated GeoNode Training Material
Francesco Bartoli xbartolone at gmail.com
Mon Jul 3 03:20:11 PDT 2017
+1 Alessio.
I’m seeing these steps mostly follow what we’ve done for the workshop and imho it matters. I would just point out to users that the deployment through vagrant and virtual box with NAT configuration is a special case of networking which can be  called “GeoNode behind a proxy” (i.e. squid) while the most of help requests from users are coming for the situation where Apache/NGINX is directly published on Internet without a proxy. The configuration in this case could be a little bit different.
Again I’d like to maintain the section on CentOS too though, maybe at the same level of here http://training.geonode.geo-solutions.it/002_install_and_admin/002_geonode_install/index.html#geonode-vrelease-installation-on-ubuntu-16-04 but just skipping the first three preliminary sections for that.
I already have a docs review WIP in my pocket for CentOS, so could make PR after your backport.
However definitively a needed step to a clearer installation process.
Many thanks,
Francesco
Il giorno 03/lug/2017, alle ore 10:52, Alessio Fabiani <alessio.fabiani at geo-solutions.it> ha scritto:
> Dear all,
> just wanted to point out an updated version of the GeoNode training material, especially the installation and configuration sections (Ubuntu, Vagrant and PPA)
> Some section are still to be updated (mostly the exercises) but it may give to users some better understanding on how to deal with GeoNode 2.7.x+ and customized GeoNode Projects.
> Please report your comments and feedbacks. As soon as we will have the final version, we will backport this material to the official GeoNode Documentation.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170703/e8a85645/attachment-0001.html>
More information about the geonode-users mailing list
