[GeoNode-users] Issue on updateip in migration to 2.6
Annalisa Schiavon annalisa.schiavon at gmail.com
Mon Jul 3 04:17:41 PDT 2017
I fixed the error on deleting orphan layers: the upload_upload table hasn't
4 attribute: mosaic_time_regex, mosaic_time_value, mosaic_elev_regex
and mosaic_elev_value. Adding those columns, I can delete my orphan layers.
It may be an issue of geonode migrate command?
Cheers,
Annalisa
2017-07-03 12:14 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Thanks!  Yes, if I replace it, it works.
> For the stale layers, I can't remove them from the admin panel, It gives
> error! I try to remove from DB, checking dependencies, ok?
> Thanks again
> 2017-07-03 11:31 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Annalisa, layer preview from geoserver seems to have a bug in the url of
>> the preview itself
>> if you right click and copy the url you'll notice it has two "?". if you
>> replace the second one with "&" then should work. This will probably be
>> fixed in next gs releases
>> 2017-07-03 11:21 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com
>>> Hi Toni,
>>> 2017-07-03 10:07 GMT+02:00 Toni Schönbuchner <
>>> toni.schoenbuchner at csgis.de>:
>>>> Hi Annalisa,
>>>> I setted the ip address in geonode-oauth2 in a couple of lines they
>>>> still
>>>> point to "localhost“.
>>>> You could grep your files to see if somewhere localhost is still
>>>> mentioned:
>>>> grep -rn --include="*.py“ „192.68.31.80" 2>/dev/null
>>> Ok, but now it seems that localhost should remain in some settings,
>>> maybe?
>>>> Here it is an example of a wrong preview link:
>>>> http://192.168.31.80/geoserver/geonode/wms?access_token=SFtO
>>>> 1m1uwzKVWzOmJmsQi72nMQyEfi?service=WMS&version=1.1.0&request
>>>> =GetMap&layers=geonode:v_staz_aria_attive&styles=&bbox=16472
>>>> 77.811,4991070.397,1798213.0,5117620.0&width=768&height=643&
>>>> srs=EPSG:3003&format=application/openlayers
>>>> You want the local IP to be a public, right?
>>>> Stupid question. Have you restarted your web servers?
>>> After checking all, I'll have to change it to a domain ... Yes, I've
>>> restarted apache and tomcat
>>>> Then, I've some old layers in geonode that doesn't more exists in
>>>> geoserver. If I try to remove from geonode ui It fails. Also the
>>>> "geonode
>>>> updatelayers --remove-deleted" fails on those layers
>>>> updatelayers has a verbose option.
>>>> http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt
>>>> _commands/#updatelayers
>>>> can you provide a detailed error output?
>>>> There are geonode commands for clean or syncronize databases? Some docs?
>>>> syncdb is now deprecated, right?
>>>> I think to remember that from Django 1.9 synchdb is depreceated.
>>>> Instead migrate
>>>> should work. F.e.:
>>>> python manage.py migrate auth# performs migrations for auth and contenttypes contrib apps
>>>> python manage.py migrate --run-syncdb# creates the rest of the database
>>>> I couldn´t find any updated documentation either.
>>>> When searching for things like that I often have a look in pavement.py
>>>> https://github.com/GeoNode/geonode/blob/master/pavement.py#L213
>>>> Thanks
>>> Annalisa
>>>> Cheers,
>>>> Toni
>>>> CSGIS
>>>> Kolonnadenstraße 1
>>>> 04109 Leipzig
>>>> Mobil +49/ (0) 176 6680 3198 <+49%20176%2066803198>
>>>> Tel  +49/ (0) 341 24 04 738 <+49%20341%202404738>
>>>> Fax  +49/ (0) 341 24 04 73 <+49%20341%20240473>
>>>> Web http://csgis.de
>>>> Hinweis gemäß § 33 BDSG
>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>>> ausschließlich für den
>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>> diese E-Mail versehentlich
>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>> löschen Sie diese Nachricht
>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>> Vervielfältigung, Veränderung,
>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170703/7d5c3361/attachment-0001.html>
More information about the geonode-users mailing list
