[GeoNode-users] Directory uploaded/layers: Can it be cleaned?
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jul 7 09:40:25 PDT 2017
Hi Benjamin,
currently if you configured the server to use PostGIS and convert
shapefiles into tables, you can delete them.
If they are ratser files (geotiff and the like), maybe first double check
on GeoServer configuration the path of the store.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Jul 7, 2017 at 2:41 PM, Benjamin Ducke <benducke at fastmail.fm> wrote:
> Dear All --
> I am wondering about the directory:
> /var/www/geonode/uploaded/layers
> I don't find much about it in the docs, but it is
> clear that all uploaded layers are stored here,
> in their original form.
> My question is: What happens if the filed are deleted
> from "uploaded/layers"? This directory is growing
> fast and I would like to reclaim the disk space.
> Thanks and best,
> Benjamin
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170707/e20cd2ee/attachment-0001.html>
More information about the geonode-users mailing list
