[GeoNode-users] python manage.py Error
Ariel Neri ariel.neriw at gmail.com
Wed Jul 12 07:06:10 PDT 2017
Thanks George, I saw that before, but since i´m not  a programmer and not
using the same version as the linked issue, i´m afraid to screw it up worse.
But i bleieve it´s related to django version, as you said.
Is GeoNode 2.6 using DJango 1.11.3? I want to make sure i didn´t change
version.
Thanks!
2017-07-12 6:04 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
> Check this conversation. It could help. https://github.com/translate/
> pootle/issues/4537
> George
> 2017-07-11 20:21 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>> I followed the quick install: http://docs.geonode.o
>> rg/en/master/tutorials/install_and_admin/quick_install.html
>> I also tried to install "django-debug-toolbar" according to this link:
>> link: https://geonode.readthedocs.io/en/2.0/tutorials/admin/
>> debugging.html
>> but since it was throwing an internal server error, I removed the changes
>> done in local_settings.py back to original. Maybe that was a bad move.
>>  Django version 1.11.3   (checked w  print(django.get_version())
>> 2017-07-11 12:59 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
>>> Hi Ariel,
>>> Maybe this issue is related with your Django version. Which guide did
>>> you follow to install GeoNode ?
>>> George
>>> 2017-07-11 17:57 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>>>> Hi, I´m running GeoNode 2.6 in ubuntu server 16.04. I´m getting the
>>>> following errors when running updatelayers:
>>>> geonode at geonode:~/my_geonode$ python manage.py updatelayers
>>>> Traceback (most recent call last):
>>>>   File "manage.py", line 11, in <module>
>>>>     execute_from_command_line(sys.argv)
>>>>   File "/home/geonode/.local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>> line 363, in execute_from_command_line
>>>>     utility.execute()
>>>> line 337, in execute
>>>>     django.setup()
>>>>   File "/home/geonode/.local/lib/python2.7/site-packages/django/__init__.py",
>>>> line 22, in setup
>>>>     configure_logging(settings.LOGGING_CONFIG, settings.LOGGING)
>>>>   File "/home/geonode/.local/lib/python2.7/site-packages/django/utils/log.py",
>>>> line 75, in configure_logging
>>>>     logging_config_func(logging_settings)
>>>>   File "/usr/lib/python2.7/logging/config.py", line 794, in dictConfig
>>>>     dictConfigClass(config).configure()
>>>>   File "/usr/lib/python2.7/logging/config.py", line 576, in configure
>>>>     '%r: %s' % (name, e))
>>>> ValueError: Unable to configure handler 'null': Cannot resolve
>>>> 'django.utils.log.NullHandler': No module named NullHandler
>>>> I have connected geoserver w a Postgis database, and it worked fine
>>>> when i had only those layers. Then I loaded new layers via GeoNode web, and
>>>> the command stopped working.
>>>>  "Collectstatic" command is throwing the same error.
>>>> I did not change LOGGING in settings.py. and did not override in
>>>> local_settings.py
>>>> I did changes according to this http://docs.geonode.org/e
>>>> n/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html.
>>>> I´m not a programmer so please, take that in account on your
>>>> suggestions or answers. Thanks!
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Πετράκης Γεώργιος
>>> Τοπογράφος Μηχανικός, Msc
>>> Τηλ: 2810-288363
>>> Κιν: 6984871889
> Πετράκης Γεώργιος
> Τηλ: 2810-288363
> Κιν: 6984871889
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/f057261a/attachment.html>
More information about the geonode-users mailing list
