[GeoNode-users] ACTIVITY Feed - Option
Naresh N naresh919 at gmail.com
Wed Jul 12 21:32:08 PDT 2017
Dear Simone,
 kindly help me  how to set new limit value for People and Groups list
Best Regards,
Naresh
On Wed, Jul 12, 2017 at 4:49 PM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Simone,
>      After removing the line  also ,the user list is not available, it is
> showing empty.
>      I have reverted the changes i.e commenting the line in url.py and
> profile_details.html  and done changes like as follows in the
>  C:\GeoNode-2.4.x\geonode-2.4.x\geonode\templates\actstream\actor.html ,
> now it is working fine
> *{% if user.is_superuser or request.user == actor %} *after line number 24
>  It may not be professional way to do, I did not get any other option, so
> with the following now it is working fine.
>  Once again thanks for the support.
> *Kindly help me in following new issue*
> How to limit the no of results showing to max 10 only , as of now default
> limit is 100.
> I mean in following url limit is 100
> http://192.168.197.108/people/?limit=100&offset=0
> To do the change the limit value in settings.py  i have
> modified CLIENT_RESULTS_LIMIT =10   and    max_limit=10 in the file
> GeoNode-2.4.x\geonode-2.4.x\geonode\api\resourcebase_api.py
> After doing above changes layers,maps,documents is working as per the new
> updated limit value 10,.
> However people,groups url showing like http://192.168.197.108/people/
> ?limit=10&offset=0,http://192.168.197.108/groups/?limit=10&offset=0, but
> if you change the limit value in url more than 10,
>  it is displaying the result more than 10(as per given limit value)
> Please kindly suggest me how to enable  new limit value to People, Groups
> list also
> Best Regards,
> Naresh
> On Wed, Jul 12, 2017 at 12:53 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Sorry. Commenting the line in the HTML is not enough. You have to remove
>> it.
>> Il giorno mer 12 lug 2017 alle 08:18 Naresh N <naresh919 at gmail.com> ha
>> scritto:
>>> Dear Simone,
>>>   Thanks for the response. After commenting following two lines, it did
>>> not working as per expected.
>>> https://github.com/GeoNode/geonode/blob/master/geonode/peopl
>>> e/templates/people/profile_detail.html#L130 and
>>> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
>>> In this case also Not able to see the user list,please find the below
>>> screenshot for reference
>>> [image: Inline image 1]
>>> Please find below my requirement, I want on click of People, the user
>>> list should be available as follows and there should not be no option to
>>> see the activity feed of the user.
>>> [image: Inline image 2]
>>>   Even if user know direct url of the activity feed, he should not able
>>> to see the activity feed, I mean with the url
>>> http://192.168.197.108/activity/actors/31/5/  now I am able to see the
>>> activity feed. So even with direct url user should not see activity feed
>>> Please help me to do the task.
>>> Best Regards,
>>> Naresh. N
>>> On Tue, Jul 11, 2017 at 6:16 PM, Simone Dalmasso <
>>>> You have to comment out the activity button in the template of profile
>>>> detail too https://github.com/GeoNode/geonode/blob/master/geonode/
>>>> people/templates/people/profile_detail.html#L130
>>>> 2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>> Thanks for quick response
>>>>>  I have commented the line 86 i.e. (r'^activity/',
>>>>> include('actstream.urls')), then we are not able to see peoples profile
>>>>> list. I want only activity feed should not be visible/accessible to the
>>>>> users. Please suggest
>>>>> Best Regards,
>>>>> Naresh
>>>>> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
>>>>>> Hi, you could exclude the activity urls by commenting this line
>>>>>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear All,
>>>>>>>  Please any body can share how to disable activity stream option for
>>>>>>> all the users.
>>>>>>> With Best Regards,
>>>>>>> Naresh
>>>>>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Dear Fabiani,
>>>>>>>>  Thanks for sharing the links, I will go through the links
>>>>>>>> Best Regards,
>>>>>>>> Naresh
>>>>>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>> Hi,
>>>>>>>>> recently I have rebuilt almost from scratch the source code of
>>>>>>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>>>>>>> You can find the GeoNode module here
>>>>>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>>>>>> It actually depends on this one
>>>>>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-
>>>>>>>>> geoexplorer
>>>>>>>>> which, again, references other git submodules.
>>>>>>>>> See instructions here
>>>>>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>>>>>>>>> also you need to download sources by uasing
>>>>>>>>> git submodule sync
>>>>>>>>> Regards,
>>>>>>>>> Alessio Fabiani
>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> Founder/Technical Lead
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Via di Montramito 3/A
>>>>>>>>> 55054  Massarosa (LU)
>>>>>>>>> Italy
>>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>>>>>> Geoexplorer is quite difficult to modify, and I don't know where
>>>>>>>>>> you could do such change.
>>>>>>>>>> Here's a very minimal documentation on how to make geoexplorer
>>>>>>>>>> work in dev mode but then not sure how you can compile it back and deploy
>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>>>>>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>  Yes as told functionality is working properly based on
>>>>>>>>>>> permissions as geoserver handling the styling option. But if user is not
>>>>>>>>>>> having permission if he does the style change,after that showing error
>>>>>>>>>>> message like as follows, user time will waste it is better if we disable
>>>>>>>>>>> based on previliges. How Edit option is implemented, kindly tell us where i
>>>>>>>>>>> need to modify the functionality
>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>>>>>>> anyway,
>>>>>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone and all,
>>>>>>>>>>>>>   One more query, please help me to do
>>>>>>>>>>>>>  If user has option for visualizing the layer and not having
>>>>>>>>>>>>> style option, then also Style icon is enabled mode in Map and Layer Window
>>>>>>>>>>>>> of GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>>>>>>> having permission for add/edit style
>>>>>>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>>>>>>> *   [image: Inline image 1]*
>>>>>>>>>>>>> How to enable/disable style icon based on user privileges for
>>>>>>>>>>>>> styling the data
>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This
>>>>>>>>>>>>>>> is the app geonode is using to implement the activity stream.
>>>>>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>    Is it possible Activity Feed of the People  should be
>>>>>>>>>>>>>>>> visible to other users based on user settings?
>>>>>>>>>>>>>>>>  I mean in following screenshot , I could able to see the
>>>>>>>>>>>>>>>> activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b746a27c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b746a27c/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b746a27c/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b746a27c/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b746a27c/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b746a27c/attachment-0009.png>
More information about the geonode-users mailing list
