[GeoNode-users] ACTIVITY Feed - Option
Naresh N naresh919 at gmail.com
Fri Jul 14 04:40:52 PDT 2017
Dear Simone,
  Thanks for response and explanation.
With Best Regards,
Naresh
On Fri, Jul 14, 2017 at 4:31 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> I see, then is ok to set hard limit server side.
> client side means that the browser request for the correct number of
> results while the server can serve any number.
> Anyway, if that works for you, that's ok.
> 2017-07-14 12:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>   Thanks for the detailed explanation.  Is  first parameter means limit
>> and second parameter means API_LIMI_PER_PAGE?
>>   I am not able to understand  client side only means ... display limit
>> in geonode should be handled on the* client side only* by setting the
>> CLIENT_RESULTS_LIMIT . Kindly explain me little more understand the
>> concept.
>>   Actually,    If we not put limit, if some users wantedly misleadingly
>> gives more number ,entire our server network bandwidth will block,for that
>> reason we want to put some upper limit (not exactly 10)and behind this any
>> number gives also
>>   it should not return the results.
>> Thanks&Regards,
>> Naresh
>> On Fri, Jul 14, 2017 at 3:35 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Dear Naresh,
>>> the change you've made on the server side will prevent anyone to request
>>> more that 10 results per time, this means that if someone wants to use the
>>> apis for search purpose on the whole catalogue will only get max 10
>>> results. If this is ok for you no problem, but generally speaking the
>>> display limit in geonode should be handled on the client side only by
>>> setting the CLIENT_RESULTS_LIMIT  and API_LIMIT_PER_PAGE as you did, In
>>> Particular the first parameter will affect the pagination (the lower it is
>>> the more pages geonode will display) while the second affects the number of
>>> results requested to the backend (the limit parameter in the url).
>>> Hope this helps in clarifying it.
>>> 2017-07-14 10:23 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>  In present GeoNode setup default the no. of results display is 100, I
>>>> mean
>>>>  http://192.168.197.108/layers/?limit=100&offset=0
>>>>  http://192.168.197.108/maps/?limit=100&offset=0
>>>>  http://192.168.197.108/groups/?limit=100&offset=0
>>>> http://192.168.197.108/people/?limit=100&offset=0
>>>> I want to change default limit of 100 to 10, Now I have done the
>>>> following changes and it is working fine
>>>> 1. Settings.py CLIENT_RESULTS_LIMIT = *10* and API_LIMIT_PER_PAGE =
>>>> *10*
>>>> 2. In  /geonode/api/api.py  newly added *max_limit =10* is added in
>>>> meta class of  GroupResource and Profile resouce
>>>> 3. In  /geonode/api/resourcebase_api.py  *max_limit* value is changed
>>>> from NONE to *10* and *limit value to 10  *
>>>> Thanks for showing interest and know the issue. Please suggest ,is any
>>>> other better method is available to fix the issue.
>>>> With Best Regards,
>>>> Naresh
>>>> On Fri, Jul 14, 2017 at 1:03 PM, Simone Dalmasso <
>>>>> Sorry, could you please explain your issue again?
>>>>> 2017-07-13 6:32 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>  kindly help me  how to set new limit value for People and Groups list
>>>>>> Best Regards,
>>>>>> Naresh
>>>>>> On Wed, Jul 12, 2017 at 4:49 PM, Naresh N <naresh919 at gmail.com>
>>>>>> wrote:
>>>>>>> Dear Simone,
>>>>>>>      After removing the line  also ,the user list is not available,
>>>>>>> it is showing empty.
>>>>>>>      I have reverted the changes i.e commenting the line in url.py
>>>>>>> and profile_details.html  and done changes like as follows in the
>>>>>>>  C:\GeoNode-2.4.x\geonode-2.4.x\geonode\templates\actstream\actor.html
>>>>>>> , now it is working fine
>>>>>>> *{% if user.is_superuser or request.user == actor %} *after line
>>>>>>> number 24
>>>>>>>  It may not be professional way to do, I did not get any other
>>>>>>> option, so with the following now it is working fine.
>>>>>>>  Once again thanks for the support.
>>>>>>> *Kindly help me in following new issue*
>>>>>>> How to limit the no of results showing to max 10 only , as of now
>>>>>>> default limit is 100.
>>>>>>> I mean in following url limit is 100
>>>>>>> To do the change the limit value in settings.py  i have
>>>>>>> modified CLIENT_RESULTS_LIMIT =10   and    max_limit=10 in the file
>>>>>>> GeoNode-2.4.x\geonode-2.4.x\geonode\api\resourcebase_api.py
>>>>>>> After doing above changes layers,maps,documents is working as per
>>>>>>> the new updated limit value 10,.
>>>>>>> However people,groups url showing like
>>>>>>> http://192.168.197.108/people/?limit=10&offset=0,http://192.
>>>>>>> 168.197.108/groups/?limit=10&offset=0, but if you change the limit
>>>>>>> value in url more than 10,
>>>>>>>  it is displaying the result more than 10(as per given limit value)
>>>>>>> Please kindly suggest me how to enable  new limit value to People,
>>>>>>> Groups list also
>>>>>>> Best Regards,
>>>>>>> Naresh
>>>>>>> On Wed, Jul 12, 2017 at 12:53 PM, Simone Dalmasso <
>>>>>>>> Sorry. Commenting the line in the HTML is not enough. You have to
>>>>>>>> remove it.
>>>>>>>> Il giorno mer 12 lug 2017 alle 08:18 Naresh N <naresh919 at gmail.com>
>>>>>>>> ha scritto:
>>>>>>>>> Dear Simone,
>>>>>>>>>   Thanks for the response. After commenting following two lines,
>>>>>>>>> it did not working as per expected.
>>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/peopl
>>>>>>>>> e/templates/people/profile_detail.html#L130 and
>>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86
>>>>>>>>> In this case also Not able to see the user list,please find the
>>>>>>>>> below screenshot for reference
>>>>>>>>> [image: Inline image 1]
>>>>>>>>> Please find below my requirement, I want on click of People, the
>>>>>>>>> user list should be available as follows and there should not be no option
>>>>>>>>> to see the activity feed of the user.
>>>>>>>>> [image: Inline image 2]
>>>>>>>>>   Even if user know direct url of the activity feed, he should
>>>>>>>>> not able to see the activity feed, I mean with the url
>>>>>>>>> http://192.168.197.108/activity/actors/31/5/  now I am able to
>>>>>>>>> see the activity feed. So even with direct url user should not see activity
>>>>>>>>> feed
>>>>>>>>> Please help me to do the task.
>>>>>>>>> Best Regards,
>>>>>>>>> Naresh. N
>>>>>>>>> On Tue, Jul 11, 2017 at 6:16 PM, Simone Dalmasso <
>>>>>>>>>> You have to comment out the activity button in the template of
>>>>>>>>>> profile detail too https://github.com/GeoNode
>>>>>>>>>> /geonode/blob/master/geonode/people/templates/people/profile
>>>>>>>>>> _detail.html#L130
>>>>>>>>>> 2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>> Thanks for quick response
>>>>>>>>>>>  I have commented the line 86 i.e. (r'^activity/',
>>>>>>>>>>> include('actstream.urls')), then we are not able to see peoples profile
>>>>>>>>>>> list. I want only activity feed should not be visible/accessible to the
>>>>>>>>>>> users. Please suggest
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
>>>>>>>>>>>> Hi, you could exclude the activity urls by commenting this line
>>>>>>>>>>>> urls.py#L86.
>>>>>>>>>>>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>  Please any body can share how to disable activity stream
>>>>>>>>>>>>> option for all the users.
>>>>>>>>>>>>> With Best Regards,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>> Dear Fabiani,
>>>>>>>>>>>>>>  Thanks for sharing the links, I will go through the links
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>>>>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> recently I have rebuilt almost from scratch the source code
>>>>>>>>>>>>>>> of GeoExplorer and aligned with live code in order to make it updatable.
>>>>>>>>>>>>>>> You can find the GeoNode module here
>>>>>>>>>>>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>>>>>>>>>>>> It actually depends on this one
>>>>>>>>>>>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-
>>>>>>>>>>>>>>> geoexplorer
>>>>>>>>>>>>>>> which, again, references other git submodules.
>>>>>>>>>>>>>>> See instructions here
>>>>>>>>>>>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-so
>>>>>>>>>>>>>>> urces
>>>>>>>>>>>>>>> also you need to download sources by uasing
>>>>>>>>>>>>>>> git submodule sync
>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>>>>>>> 55054  Massarosa (LU)
>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>>>>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>>>>>>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>>>>>>> The information in this message and/or attachments, is
>>>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Geoexplorer is quite difficult to modify, and I don't know
>>>>>>>>>>>>>>>> where you could do such change.
>>>>>>>>>>>>>>>> Here's a very minimal documentation on how to make
>>>>>>>>>>>>>>>> geoexplorer work in dev mode but then not sure how you can compile it back
>>>>>>>>>>>>>>>> and deploy http://docs.geonode.org
>>>>>>>>>>>>>>>> /en/master/tutorials/devel/dev
>>>>>>>>>>>>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>>>>>>>>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>  Yes as told functionality is working properly based on
>>>>>>>>>>>>>>>>> permissions as geoserver handling the styling option. But if user is not
>>>>>>>>>>>>>>>>> having permission if he does the style change,after that showing error
>>>>>>>>>>>>>>>>> message like as follows, user time will waste it is better if we disable
>>>>>>>>>>>>>>>>> based on previliges. How Edit option is implemented, kindly tell us where i
>>>>>>>>>>>>>>>>> need to modify the functionality
>>>>>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> Not sure it's easily achievable as would require
>>>>>>>>>>>>>>>>>> geoexplorer development. Although the permission should be respected by
>>>>>>>>>>>>>>>>>> geoserver anyway,
>>>>>>>>>>>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>>>>>>>>> Dear Simone and all,
>>>>>>>>>>>>>>>>>>>   One more query, please help me to do
>>>>>>>>>>>>>>>>>>>  If user has option for visualizing the layer and not
>>>>>>>>>>>>>>>>>>> having style option, then also Style icon is enabled mode in Map and Layer
>>>>>>>>>>>>>>>>>>> Window of GeoNode interface. Can we grey out Style icon in case if user has
>>>>>>>>>>>>>>>>>>> not having permission for add/edit style
>>>>>>>>>>>>>>>>>>> *NOTE: This kind of enabling/disabling icon is
>>>>>>>>>>>>>>>>>>> happening for Editing data icon. In following Edit is disable mode if user
>>>>>>>>>>>>>>>>>>> has not having edit option. How ever for Style it is not happening*
>>>>>>>>>>>>>>>>>>> *   [image: Inline image 1]*
>>>>>>>>>>>>>>>>>>> How to enable/disable style icon based on user
>>>>>>>>>>>>>>>>>>> privileges for styling the data
>>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <
>>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>   Thanks for the response, I will go through the shared
>>>>>>>>>>>>>>>>>>>> link
>>>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it.
>>>>>>>>>>>>>>>>>>>>> This is the app geonode is using to implement the activity stream.
>>>>>>>>>>>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>    Is it possible Activity Feed of the People  should
>>>>>>>>>>>>>>>>>>>>>> be visible to other users based on user settings?
>>>>>>>>>>>>>>>>>>>>>>  I mean in following screenshot , I could able to see
>>>>>>>>>>>>>>>>>>>>>> the activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/2816f2bb/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/2816f2bb/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/2816f2bb/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/2816f2bb/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/2816f2bb/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/2816f2bb/attachment-0009.png>
More information about the geonode-users mailing list
