[GeoNode-users] I can't upload layers
Annalisa Schiavon annalisa.schiavon at gmail.com
Tue Jul 18 00:53:50 PDT 2017
Hi Francesco!
I run the command you suggest and I receive
curl http://localhost:8080/geoserver/rest/workspaces.json
{"workspaces":""}
I do not understand what is misconfigured in my Geoserver-Geonode!
Than, I set Active role Service = default in Geoserver (Security Settings)
and I could upload my layer ...
Now I set again Active role Service = geonode REST role service and I get
this Warning in geoserver log:
WARN [geofence.cache] -
org.geoserver.geofence.cache.CachedRuleReader$NoAuthException: Can't auth
user [admin]
2017-07-17 16:46 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Hi Annalisa,
> can you try to make a curl call to that endpoint from within the server?
> Basically connect through ssh and then run from the shell:
> $ curl http://localhost:8080/geoserver/rest/workspaces.json
> you should receive something like
> {"workspaces":""}
> If you get 404 the it's likely geoserver is not routed through localhost.
> Hope this helps
> Sent from Nylas Mail
> <https://n1.nylas.com/link/82bc912f54831b3fad494772c7bf7019a669ef0039d12be59d86966dcf2688fb/0?redirect=https%3A%2F%2Fnylas.com%3Fref%3Dn1&recipient=annalisa.schiavon%40gmail.com>,
> the best free email app for work
> On lug 17 2017, at 3:15 pm, Annalisa Schiavon <annalisa.schiavon at gmail.com>
> wrote:
>> Hi all.
>> I've migrated all my old layers, but now I can't upload a layer from ui.
>> It says:
>> "Tried to make a GET request to http://localhost:8080/
>> geoserver/rest/workspaces/default.xml
>> <http://localhost:8080/geoserver/rest/workspaces/default.xml?recipient=annalisa.schiavon%40gmail.com>
>> but got a 404 status code: No such workspace: default"
>> In apache log I find:
>> ... Tried to make a GET request to http://localhost:8080/
>> ... [wsgi:error] [pid 9903:tid 139960535320320] No such workspace: default
>> In effect I have only one workspace: geonode, wich is the default one.
>> My geoserver-data-dir points to /mnt/geodata/geoserver_data and there is
>> the file /mnt/geodata/geoserver_data/workspaces/default.xml of tomcat7
>> user with 664 permission.
>> Please help!
>> Now I can login with geonode user both in geonode that in geoserver and I
>> see layers and maps and all thumbs.
>> Annalisa
>> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170718/11b250e6/attachment-0001.html>
More information about the geonode-users mailing list
