[GeoNode-users] Installation Problems with version 2.6 on Ubuntu 16.04
Cliff Patterson cliffpatterson at gmail.com
Tue Jun 20 11:09:48 PDT 2017
No access to Geoserver on the address line. Will do more testing. Might try
on the local VM to see it I can get it running.
Thanks!
Cliff
On Tue, Jun 20, 2017 at 12:48 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Ok, and you mentioned you can't log in with your superuser, this is very
> strange. Any error in the apache log? You could also turn on the DEBUG =
> True in the settings, this will give you more info on the screen.
> For the geoserver issue, are you able to reach the /geoserver address and
> see the geoserver home page?
> 2017-06-20 15:04 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
>> @simone I used the following instructions to install:
>> sudo add-apt-repository ppa:geonode/stable
>> sudo apt-get update
>> sudo apt-get install geonode
>> Then set the IP address and create a superuser.
>> geonode createsuperuser
>> sudo geonode-updateip 127.0.0.1 (replaced with my IP address)
>> There were no errors during installation. I did a thorough read of the
>> apt log at /var/log/apt/term.log and no errors reported.
>> On Tue, Jun 20, 2017 at 5:45 AM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Not an issue, just a warning. It has been already solved on master.
>>> Regards,
>>> Alessio Fabiani
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender
>>> does not give any warranty or accept liability as the content, accuracy or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Tue, Jun 20, 2017 at 7:53 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> @Cliff, could you describe again how you install GeoNode? if using
>>>> apt-get you should get errors during installation, please report them here.
>>>> @Israel, that is just an info due to db design, we can clean it up in
>>>> the future but is not an issue.
>>>> 2017-06-19 22:46 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
>>>>> No previous version installed. It was installed on a fresh OS.
>>>>> On Jun 19, 2017 4:43 PM, "Israel López" <asralf at gmail.com> wrote:
>>>>> Hi, did you have a previous version of genode installed???
>>>>> I'm testing Geonode 2.6 too, but on Develoment mode, I had similar
>>>>> issues,
>>>>> but "log-in" problem I solved running the create superuser command
>>>>> again.
>>>>> The issue that remains is this one:
>>>>> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>>>>> ManyToManyField.
>>>>> I don't understand it, but Geonode is running and working, if somebody
>>>>> could explain me
>>>>> how to fix it I will appreciate it.
>>>>> Greetings.
>>>>> 2017-06-19 11:29 GMT-05:00 Cliff Patterson <cliffpatterson at gmail.com>:
>>>>>> I finally reinstalled on a clean Ubuntu 16.04.2 (64 bit) VPS with 4GB
>>>>>> of ram and still having the same issues:
>>>>>>    1. Unable to log in with superuser credentials
>>>>>>    2. unable to fully update IP. The system hangs at "Inspecting the
>>>>>>    available layers in GeoServer ..."
>>>>>>    3. Getting the following warning during install and when running
>>>>>>    createssuperuser:
>>>>>> WARNINGS:
>>>>>> ?: (1_8.W001) The standalone TEMPLATE_* settings were deprecated in
>>>>>> Django 1.8 and the TEMPLATES dictionary takes precedence. You must put the
>>>>>> values of the following settings into your default TEMPLATES dict:
>>>>>> TEMPLATE_DIRS.
>>>>>> ManyToManyField.
>>>>>> Bottom line, even on a 4GB machine, I cannot get Geonode working.
>>>>>> Have the installation instructions changed or am I missing some critical
>>>>>> step? I'm using these: http://geonode.org/blog/2017/0
>>>>>> 5/17/geonode-2.6-released/
>>>>>> Big thanks!
>>>>>> Cliff
>>>>>> On Fri, Jun 9, 2017 at 7:25 AM, Simone Dalmasso <
>>>>>>> Hi, well 2 GB are probably not enough. 4GB are the minimum I think.
>>>>>>> You shopuld be able to find geoserver with locate geoserver, it is
>>>>>>> uncompressed in /usr/share if I'm no wrong.
>>>>>>> 2017-06-09 13:03 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com
>>>>>>>> Thanks for the reply!
>>>>>>>> I didn't see any errors (except for template warnings) during
>>>>>>>> installation. I even saw that geonode-geoserver was installed but I can't
>>>>>>>> find it post installation.
>>>>>>>> I spun it up on a VM with 4 cores and 2GB of ram on Digital Ocean.
>>>>>>>> Is this enough power for GeoNode?
>>>>>>>> Thanks again for your help!
>>>>>>>> Cheers,
>>>>>>>> Cliff
>>>>>>>> On Jun 9, 2017 3:17 AM, "Simone Dalmasso" <
>>>>>>>>> Hi, yes definitely geoserver needs to be there and the package
>>>>>>>>> should install it. Make sure your machine is powerful enough, also during
>>>>>>>>> the installation you should have gotten some errors.
>>>>>>>>> 2017-06-08 18:22 GMT+02:00 Cliff Patterson <
>>>>>>>>>> PS: and I am unable to authenticate via the geonode website.
>>>>>>>>>> On Thu, Jun 8, 2017 at 12:20 PM, Cliff Patterson <
>>>>>>>>>> cliffpatterson at gmail.com> wrote:
>>>>>>>>>>> Hello,
>>>>>>>>>>> I decided to give Geonode 2.6 a go and installed it on a fresh
>>>>>>>>>>> VM running Ubuntu 16.04.2 x64. I installed it with the following commands:
>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>> sudo geonode-updateip 67.207.87.119
>>>>>>>>>>> When creating the super user, I get the following warning:
>>>>>>>>>>> System check identified some issues:
>>>>>>>>>>> WARNINGS:
>>>>>>>>>>> in Django 1.8 and the TEMPLATES dictionary takes precedence. You must put
>>>>>>>>>>> the values of the following settings into your default TEMPLATES dict:
>>>>>>>>>>> TEMPLATE_DIRS.
>>>>>>>>>>> ManyToManyField.
>>>>>>>>>>> Username: test
>>>>>>>>>>> Email address:
>>>>>>>>>>> Password:
>>>>>>>>>>> Password (again):
>>>>>>>>>>> Superuser created successfully.
>>>>>>>>>>> When running sudo geonode-updateip 67.207.87.119, the following
>>>>>>>>>>> happens:
>>>>>>>>>>> 1) Hangs on "Inspecting the available layers in GeoServer ..."
>>>>>>>>>>> 2) Geonode does get up and running at 67.207.87.119 but no
>>>>>>>>>>> ability to login
>>>>>>>>>>> Replacing SITEURL value with '67.207.87.119' in
>>>>>>>>>>> /etc/geonode/local_settings.py ... done.
>>>>>>>>>>> Adding entry for '67.207.87.119' in
>>>>>>>>>>> /usr/share/geoserver/data/printing/config.yaml ... done.
>>>>>>>>>>> Adding ALLOWED_HOSTS with in /etc/geonode/local_settings.py ...
>>>>>>>>>>> done.
>>>>>>>>>>> Setting up oauth
>>>>>>>>>>> Am I missing something in the instructions? Do we need to
>>>>>>>>>>> install Geoserver on Tomcat7 first, then Geonode? As far as I can see,
>>>>>>>>>>> Geoserver has not been installed, which I thought was part of the geonode
>>>>>>>>>>> installation, but I could be wrong.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>> Simone
>>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/c16407d5/attachment-0001.html>
More information about the geonode-users mailing list
