[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Tue Jun 20 23:24:51 PDT 2017
Dear Simone,
  Thanks once again. I am trying to resolve, but not able to do. Kindly
explain following little more, which will help to resolve
1.The WMS URL request  i.e
http://fase2kort.klimatilpasning.dk:80/geoserver/wms is first  reaching to
GeoNode deployed system and from it , the request is going to corresponding
URL.
  In this case GeoNode deployed system to send the url ,it required proxy
server our campus network .* Is it true?* If so  I have to specify our
proxy server address in GeoNode Code. Where I have to specify?
2. Even if it works the GeoNode deployed system should have internet
connectivity.* Is it true*?
3. As of now my GeoNode deployed System has internet connectivity, how ever
once we make this application live/production, the internet connectivity
will be removed for security concerns
             (As you aware production servers should not have internet to
avoid possible threats)
  *          In this case how to handle?*
*4. * Is there any way is available , if user specifies WMS Layer URL and
Name it should load  and add corresponding layers to GeoNode  Map/Layer
window
Please kindly help me to understand
Thanks,
Naresh
On Tue, Jun 20, 2017 at 5:49 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Unfortunately I don't have any other advice, if the server is properly
> connected to the internet and is correctly accessing it, then it should
> work without requiring specific settings but the PROXY_ALLOWED_HOSTS, which
> you already set.
> 2017-06-20 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>> Thanks for the responses
>> As you told the following request getting proper response
>> http://demo.geonode.org/proxy/?url=http%3A%2F%2Ffase2kort.kl
>> imatilpasning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26RE
>> QUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
>> and in case of my geonode  the following request is getting the error
>> http://localhost/proxy/?url=http%3A%2F%2Ffase2kort.klimatilp
>> asning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%
>> However in my browser with the url : http://fase2kort.klimatilpas
>> ning.dk/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&TI
>> LED=true&VERSION=1.1.1, it is getting proper respone
>> Do I need to add *my proxy server address some where in GeoNode code*?
>> or proxy address will take directly from the system?  I have also asked
>> network administrator, but  they are not able to understand
>> As you know, this functionality is very much important, as it will
>> connect others server and fetch the data . Please  suggest some clue to
>> resolve
>> Thanks,
>> Naresh
>> On Tue, Jun 20, 2017 at 5:13 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> No, that server is not responding to ping so it will never work. Not
>>> sure what setting you need for the server but to me it looks an error
>>> related to your network. On demo.geonode.org is, for example, working.
>>> 2017-06-20 12:45 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>   I have opened the terminal in  my server(Geonode deployed system) and
>>>> typed the ping  fase2kort.klimatilpasning.dk, but not getting
>>>> connected. Do I need to change/add my server settings?
>>>> Thanks,
>>>> Naresh
>>>> On Tue, Jun 20, 2017 at 3:46 PM, Simone Dalmasso <
>>>>> Ok so maybe your server is unable to reach that address, can you check
>>>>> that?
>>>>> 2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>  when I opened the http://fase2kort.klimatilp
>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers, it
>>>>>> is showine geoserver related error. Please find the attached response file
>>>>>> for you  reference.
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
>>>>>>> It might be. Are you able to access that wms backend from in the
>>>>>>> browser? http://fase2kort.klimatilpasning.dk:80/geoserver/wms
>>>>>>> it should give you an XML containing the geoserver error related to
>>>>>>> missing request parameter.
>>>>>>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>   Yes we are in office campus, we are using proxy server. So  is
>>>>>>>> this the reason?  if so where I need to do the changes?
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>>>>>>> At this point I would check your local internet connection, are
>>>>>>>>> you behind a proxy that may block it?
>>>>>>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>   Thanks for the responding.  As per I understand from below code
>>>>>>>>>> in the proxy/views.py
>>>>>>>>>> if not settings.DEBUG:
>>>>>>>>>>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>>>>>>>>>             return HttpResponse("DEBUG is set to False but the
>>>>>>>>>> host of the path provided to the proxy service"
>>>>>>>>>>                                 " is not in the
>>>>>>>>>> PROXY_ALLOWED_HOSTS setting.",
>>>>>>>>>>                                 status=403,
>>>>>>>>>>                                 content_type="text/plain"
>>>>>>>>>>  if GeoNode  debug mode value is flase, the wms url may not be
>>>>>>>>>> required to add in  PROXY_ALLOWED_HOSTS. And even if debug mode
>>>>>>>>>> value is ture, it should show the following error 'DEBUG is set
>>>>>>>>>> to False but the host of the path provided to the proxy service"
>>>>>>>>>>                                 " is not in the
>>>>>>>>>> PROXY_ALLOWED_HOSTS setting',. In my case nothing this kind of error/alert
>>>>>>>>>> message is not getting
>>>>>>>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode
>>>>>>>>>> site, it is fetching the layers
>>>>>>>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>>>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it
>>>>>>>>>> is showing same error.
>>>>>>>>>> I have been trying from last two days to overcome this issue, but
>>>>>>>>>> not able to do. Please suggest anywhere more I need to investigate the
>>>>>>>>>> code/settings?
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in
>>>>>>>>>>> the PROXY_ALLOWED_HOSTS directive as every remote address should be
>>>>>>>>>>> authorised there.
>>>>>>>>>>> I tested locally and seems to work.
>>>>>>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>>>>>>> is solved.
>>>>>>>>>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>>>>>>>>>> following error.
>>>>>>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>>>>>>> Internal Server Error: /proxy/
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629]
>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py",
>>>>>>>>>>>> line 112, in get_response
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response
>>>>>>>>>>>> = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>>>>>>> self._send_request(method, url, body, headers)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>>>>>>> self.endheaders(body)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>>>>>>> self._send_output(message_body)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629]
>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629]
>>>>>>>>>>>> self.connect()
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629]
>>>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in
>>>>>>>>>>>> create_connection
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>>>>>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error:
>>>>>>>>>>>> [Errno 111] Connection refused
>>>>>>>>>>>> Even I went to httplib.py and socket.py with the alerts I could
>>>>>>>>>>>> able to see the following WMS server IP and port details ('188.64.159.9',
>>>>>>>>>>>> 80) and source_address is none
>>>>>>>>>>>> Please help me how to resolve the issue, is that any where my
>>>>>>>>>>>> GeoNode Deployed System Ip need to place?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>>>>>>> It must be an array and not a tuple.
>>>>>>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <
>>>>>>>>>>>>> naresh919 at gmail.com> ha scritto:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410]
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410]
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410]
>>>>>>>>>>>>>> TypeError: cannot concatenate 'str' and 'tuple' objects
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409]
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409]
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL
>>>>>>>>>>>>>> Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>> if in proxy/views.py if i add in place of hostname ip adress
>>>>>>>>>>>>>> of the GeoNode, The error '*TypeError: cannot concatenate
>>>>>>>>>>>>>> 'str' and 'tuple' objects ' *will go, how ever the error
>>>>>>>>>>>>>> which I mentioned in my earlier mail retains.
>>>>>>>>>>>>>> Please suggest how to overcome above error '*TypeError:
>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects ' *with out
>>>>>>>>>>>>>> editing proxy/views.py
>>>>>>>>>>>>>> And also kindly suggest me how to correct misconfiguration of
>>>>>>>>>>>>>> SSL error, since I am not using https any where
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>>>>>>> Anyway, seems you are running under ssl. Seems a
>>>>>>>>>>>>>>> misconfiguration of it.
>>>>>>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the
>>>>>>>>>>>>>>>> following error.
>>>>>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>>>>>> *Please find the apaahe error log file and attached
>>>>>>>>>>>>>>>> views.py file from proxy folder of geonode for the reference. In view.py in
>>>>>>>>>>>>>>>> line no: 37 is modified (commented host name and placed IP adrdress of
>>>>>>>>>>>>>>>> GeoNode installed system)*
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib/python2.7/site-packa
>>>>>>>>>>>>>>>> ges/django/core/handlers/base.py", line 112, in
>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/data/cms/geonode/geonode/proxy/views.py", line 67,
>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1017, in
>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1051, in
>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1013, in
>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 864, in
>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 807, in
>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/socket.py", line 571, in
>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> raise err
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> error: [Errno 111] Connection refused
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> raise err
>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL
>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>> Please kindly suggest me, do i need to modify some where
>>>>>>>>>>>>>>>> else?
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <
>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms.
>>>>>>>>>>>>>>>>>> Not sure about our other question, don't think is possible in the standard
>>>>>>>>>>>>>>>>>> code.
>>>>>>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS
>>>>>>>>>>>>>>>>>>> Layer url is available ,please share me to test.  Is that any mechanism is
>>>>>>>>>>>>>>>>>>> available in case if WFS of Geoserver is disabled,not enabling EDIT option
>>>>>>>>>>>>>>>>>>> while reading error code.
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an
>>>>>>>>>>>>>>>>>>>> issue of that geoserver.
>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode
>>>>>>>>>>>>>>>>>>>>> using Layers ->Add server option. It is adding but it shows the issue which
>>>>>>>>>>>>>>>>>>>>> I mentioned in my earlier mail.
>>>>>>>>>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site  and  can be
>>>>>>>>>>>>>>>>>>>>> observed same issue.
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.
>>>>>>>>>>>>>>>>>>>>>> in/bhuvan/web/
>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance
>>>>>>>>>>>>>>>>>>>>>>> i  have fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which
>>>>>>>>>>>>>>>>>>>>>>> contains the steps I followed to install.
>>>>>>>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and version
>>>>>>>>>>>>>>>>>>>>>>> is 2.7.4. Not able to understand from where you  observed my Geoserver
>>>>>>>>>>>>>>>>>>>>>>> version is 2.0.2?.
>>>>>>>>>>>>>>>>>>>>>>>  Please let me know any other information required
>>>>>>>>>>>>>>>>>>>>>>> to solve the issue
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it
>>>>>>>>>>>>>>>>>>>>>>>> should be 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from
>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure
>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver with GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso
>>>>>>>>>>>>>>>>>>>>>>>>> <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4
>>>>>>>>>>>>>>>>>>>>>>>>>> guide? http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>>>>>>> /en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Installation of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps
>>>>>>>>>>>>>>>>>>>>>>>>>>>> folder.
>>>>>>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (
>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://demo.geonode.org) also I have tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>> with the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> /bhuvan/wms   , I am getting same issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dalmasso <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> in geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  using ADDLayrers---> Addsever option the following error is getting and
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> EDIT options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> this mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/9c8f2b35/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/9c8f2b35/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/9c8f2b35/attachment-0003.png>
More information about the geonode-users mailing list
