[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 23 02:04:34 PDT 2017
Thanks for the idea Naresh. The reason of authorise the address in proxy is
because the getCapabilities request will generate an XML document which the
browser would block due to cross origin. By adding the layer name we could
fetch it directly (only images )without getCapabilities (and some metadata)
but might be good enough.
2017-06-23 10:58 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear All,
>  Thanks for the responses. However, in future version if possible please
> include the option like as follows
>  There should be one button with the name---?'ADD WMS' on click of it
> opening like the following window and once we give details like url as
> http://bhuvan5.nrsc.gov.in/bhuvan/wms and layer name as
> vector:AS_LULC50K_0506
>       [image: Inline image 2]
>  Once we will get  Load option, the correspond layer details checkbox
> should be visible in Map interface of Window like as follows
>     [image: Inline image 4]
> By adding this way enables quickly  adding the layer into Map window if
> user knows the Layer name ,url directly and in coding level there is no
> requirement adding url in proxy, since from map client/Genode interface
> will directly send the requests to corresponding server and fetches the
> response.
> Best Regards,
> Naresh. N
> On Fri, Jun 23, 2017 at 1:51 PM, Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Hey Naresh,
>> if I correctly remember from heart I normally do it this way:
>> - create new map
>> - choose hadd layer select
>> > there you´ll find add server
>> - add wms server in question
>> - load layers from wms
>> However, maybe publishing the layer directly via your geoserver instance
>> does as well what you´re looking for:
>> find the docmentation here:
>> http://docs.geonode.org/en/master/tutorials/advanced/adv_dat
>> a_mgmt/adding_data/add_wmscascade.html
>> cheers,
>> toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198 <+49%20176%2066803198>
>> Tel  +49/ (0) 341 24 04 738 <+49%20341%202404738>
>> Fax  +49/ (0) 341 24 04 73 <+49%20341%20240473>
>> Web http://csgis.de
>> Am 23.06.2017 um 10:14 schrieb geonode-users-request at lists.osgeo.org:
>> Message: 1
>> Date: Fri, 23 Jun 2017 13:44:45 +0530
>> From: Naresh N <naresh919 at gmail.com>
>> To: Simone Dalmasso <simone.dalmasso at gmail.com>
>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>> Subject: Re: [GeoNode-users] Issues adding WMS URL in GeoNode
>> Message-ID:
>> <CAKAPXzO5fQn0Kjwaq0CbYbOSuj-RKJM3Yyuoq5g-rLAMcJ2pRA at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Dear Simone,
>>   Thanks for the response.
>>    Is it possible to add WMS Layer with Layer Name and URL to GeoNode
>> interface. If not where do I need to write a script for taking the input
>> WMS URL , Layer Name and adding to Overlay layers section in Map window
>> Thanks,
>> Naresh
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/074658c2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/074658c2/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/074658c2/attachment-0003.png>
More information about the geonode-users mailing list
