[GeoNode-users] how to make the local geonode accessible on the world wide web
Toni Schönbuchner toni.schoenbuchner at csgis.de
Mon Jun 26 08:08:40 PDT 2017
Dear Elisa,
yes it would be possible to make your local network accessible to the world
but this is not adviseable at all.
First you would need a static IP or use a dynamic IP service like duckdns to map
a domain to your always changing IP address (after that you could indeed advise
your local server and geonode to listen to it).
Next your upload will most likely not be strong enough to serve the content to all
clients outside and last to all abound, you would have to take care that nobody
accesses files in your lan (security issues).
To make a long story short. I can only advicse you to rent a server to host
your geonode installation. Depending where you live I would choose a provider
and start with a single VM. (If your´re not familiar with server managment maybe a
managed solution would be good).
Find here the technical requirements for geocode to run:
http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html#quick-installation <http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html#quick-installation>
Hope this helps a bit.
Cheers,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil	+49/ (0) 176 6680 3198
Tel 		+49/ (0) 341 24 04 738
Fax 		+49/ (0) 341 24 04 73
Web		http://csgis.de
> Am 26.06.2017 um 16:45 schrieb geonode-users-request at lists.osgeo.org:
> Message: 4
> Date: Mon, 26 Jun 2017 16:45:01 +0200
> From: Elisa Pruvot <pruvotelisa at gmail.com <mailto:pruvotelisa at gmail.com>>
> To: geonode-users <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
> Subject: [GeoNode-users] how to make the local geonode accessible on
> 	the	world wide web
> Message-ID:
> 	<CAE2K2eRPVLHBaYnaepBcsQZMtjS-=0qWP-QX9Xd_ass840usnA at mail.gmail.com <mailto:CAE2K2eRPVLHBaYnaepBcsQZMtjS-=0qWP-QX9Xd_ass840usnA at mail.gmail.com>>
> Content-Type: text/plain; charset="utf-8"
> Hi everyone !
> I'm running GeoNode 2.6 on Ubuntu 16.04 on the local network of the office
> I work in. Currently I access to geonode on local network with the IP
> adress of the computer.
> But I'd like to make GeoNode accessible on the web by anyone with a real
> URL.
> Could someone guide me to do so ? Is there a file where it should be
> configured ? Do I need to call a telecommunications network administrator
> or something ?
> Thanks, Elisa
> Elisa Pruvot
> M2 SIGAT
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170626/56cde660/attachment-0001.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170626/56cde660/attachment-0001.sig>
More information about the geonode-users mailing list
