[GeoNode-users] SLD and Geonode
Fosco Ventura foscone at gmail.com
Tue Jun 27 10:08:05 PDT 2017
Thanks to everyone for the many solutions, I'm going to try them all.
Regards
Fosco
2017-06-27 12:19 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Dear Francesco,
> there is some ongoing work on this topic from our side.
> We are working both on QGIS side in order to fix SLD exporter issues (of
> course it won't be possible to replicate exactly *all* the QGIS style
> features, but at least it will be possible to replicate most of them) and
> on GeoNode side by trying to:
> 1. Fix an issue with GeoNode replacing the content of the attached SLD
> file with the a default one
> 2. Implement on GeoNode a functionality to allow users to upload SLDs from
> the Layer Editor GUI
> Currently, the easiest way to do it is:
> a) Upload the Layer as is; this will create on GeoServer a Style named
> exactly equal to the filename
> b) Go to GeoServer Admin > Styles and replace the style with the correct
> one by uploading it
> [image: Inline image 1]
> *NOTICE: **You need GeoServer administrator rights in order to access
> this page.*
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax:     +39 0584 1660272 <0584%20166%200272>
> mob:   +39 331 6233686 <331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Jun 27, 2017 at 12:01 PM, Fosco Ventura <foscone at gmail.com> wrote:
>> Dear list,
>> I have a question about SLD in Geonode/Geoserver.
>> I have noted that QGIS doesn't export SLD in the way that Geoserver want
>> and I have to use UDIG in order to get the correct SLD file.
>> Moreover, when I upload the SHP with its SLD file, I have to upload twice
>> the same file to make it accepted by Geoserver.
>> Is there any smarter way to do this operation?
>> Thanks a lot
>> Fosco
>> Fosco
>> http://studiotypo.it/
>> http://www.studiotypo.it/fosco/
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
Fosco
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170627/251f176d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170627/251f176d/attachment-0001.png>
More information about the geonode-users mailing list
