[GeoNode-users] How to establish a relation between a layer and a document in the GeoNode database
Simone Dalmasso simone.dalmasso at gmail.com
Wed Mar 8 12:11:30 PST 2017
What bug?
Il giorno mer 8 mar 2017 alle 20:46 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi
> Shouldn't we file a bug here and fix it in the code base?
> p
> On Wed, Mar 8, 2017 at 8:09 AM, Eloi <eloi at openmailbox.org> wrote:
> > Thanks for your quick reply Simone.
> > It was very helpful. Now I can see in a SQL query how Documents and
> Layers
> > relate:
> > SELECT d.resourcebase_ptr_id AS doc_id,
> >        l.resourcebase_ptr_id AS lay_id,
> >        d.title_en AS doc_title,
> >        l.title_en AS lay_title
> > FROM documents_document AS d
> > LEFT JOIN layers_layer  AS l ON l.resourcebase_ptr_id = d.object_id
> > ORDER BY l.title_en;
> > And I was wrong when I said "every time I run the command "python
> manage.py
> > updatelayers" all established relations (between a layers and a
> documents)
> > disappear". That is not true, they did disappear because I have delete
> the
> > layers in order to restore them again in the update. So my fault. Still
> > learning.
> > Thank you very much for the help.
> > Cheers,
> > Eloi
> > On 2017-03-08 11:50, Simone Dalmasso wrote:
> >> Hi,
> >> The layers are actually saved in the layer_layer table but the relation
> is
> >> in document_document and points to the ContentType model. It is a
> generic
> >> relation since it can point to any other geonode resource. The two
> fields
> >> that you have to compile in the document table are the contenty_type
> (the id
> >> if the layer content type in your case) and object_id(the id of the
> target
> >> layer.)
> >> Hope this helps
> >> 2017-03-08 10:05 GMT+01:00 Eloi <eloi at openmailbox.org>:
> >>> Good morning,
> >>> I would like to establish the relation between a layer and a document
> >>> using the GeoNode database and not using the web interface.
> >>> I saw that the layers are listed in table 'base_resourcebase' and
> >>> documents in 'documents_document'. So I wonder in which table the
> relation
> >>> between the previous two is recorded. Then I would just run my SQL
> code to
> >>> define does relations.
> >>> Why I want to do this? Because every time I run the command "python
> >>> manage.py updatelayers" all established relations (between a layers
> and a
> >>> documents) disappear.
> >>> Thank you in advance!
> >>> Cheers,
> >>> Eloi
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170308/85a5cca3/attachment.html>
More information about the geonode-users mailing list
