[GeoNode-users] about geonode harvesting (mutil geoserver)
Eugenio Trumpy frippe12573 at hotmail.com
Wed Mar 29 23:19:49 PDT 2017
Hi Francesco,
I checked my web.xml file of my second geoserver, actually I didn't modify anything in there,
Do you think I had to change each geoserver in geoserver2? (e.g. in each <listener-class> and <filter-class>)
Actually without this change I didn't notice particular failures.
Eugenio
Da: Francesco Bartoli <xbartolone at gmail.com>
Inviato: lunedì 27 marzo 2017 22.42
A: Eugenio Trumpy
Oggetto: Re: [GeoNode-users] about geonode harvesting (mutil geoserver)
I guess you had also to align the web.xml once the war file was unzipped just for allowing other people to understand what that would impact.
Ciao
Francesco
Il giorno 27/mar/2017, alle ore 08:49, Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> ha scritto:
just change the name of the war file, since to app with the same name in the same tomcat container doesn't work.
E.
Da: Francesco Bartoli <xbartolone at gmail.com<mailto:xbartolone at gmail.com>>
Inviato: venerdì 24 marzo 2017 08.58
A: Eugenio Trumpy
Cc: 원영진; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi Eugenio,
what do you mean with renaming geoserver?
Il giorno 23/mar/2017, alle ore 09:20, Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> ha scritto:
I'm using two geoserver too in the same server. I just renamed the geoserver from geonode in geoserver2  and modified the local_setting accordingly. Then as Simone said you can add the other geoserver as external services, and you have its layer available for creating maps.
Eugenio
Da: geonode-users <geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>> per conto di Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>
Inviato: giovedì 23 marzo 2017 07.24
A: 원영진
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi, the geonode's geoserver is one, this because that geoserver has a specific permissions and security system.
I geonode 2.4 and 2.6 you can use the "services"(you can find it on top right in your user's tab) app of Geoode to pair a remote OGC catalogue(i.e a remote geoserver) in your geonode.
2017-03-23 3:08 GMT+01:00 원영진 <icetiger at nate.com<mailto:icetiger at nate.com>>:
I am studying GEONODE for my testing and It helps so much more than we imagined.
I think this is really useful solution so I am interested in learning more about your service.
By the way, I read 'python manage.py updatelayers' of [Management Commands for GeoNode] which is linked with this:
http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt_commands/index.html#admin-mgmt-commands
and I was wondering if there is any method to add another geoserver for search layers.
I look forward to hearing from you soon.
Thank you.
( confirm 27a58647a5cf74f94975f00887102b6985d12030 )
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170330/af8c7c24/attachment-0001.html>
More information about the geonode-users mailing list
