[GeoNode-users] Increase performance for loading map, because of capabilities request
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon May 8 04:13:26 PDT 2017
Trivial solution (but also easiest to achieve and should not require any
other "particular" customization), would be to login into GeoServer ad an
internal administrator, edit the Layers to not show on the GetCapabilities
but checking-off the "Advertised" option and save them.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, May 8, 2017 at 12:49 PM, John, Steffen <s.john at atenekom.eu> wrote:
> Hi,
> none of the layers has download permission, so is isn't the reason. I'm
> logged in as admin, which has the view persmissions to all layers.
> So, is it possible to adapt geonode, geoserver to request only the
> capabilities of the layers included in the map?
> I'm quite advanced in Geonode and Geoserver, do you have ideas, how i can
> solve this problem in a different way?
> cheers,
> Steffen
> Am Montag, den 08.05.2017, 11:21 +0200 schrieb Alessio Fabiani:
> Ok, GeoNode 2.4 is quite old and still makes use of obsolete auth method,
> so I'm not fully sure this solution could work, but it is worth to try it
> out.
> For all those layers which are not public, please remove *also* the
> download permissions. You can maybe do a quick test with just one or two
> and see if they have been removed from the big GetCapabilities document.
> If this won't work either, the possible solutions are not trivial and will
> require a very good knowledge of both GeoServer and GeoNode.
> Best Regards,
> Alessio Fabiani.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax:     +39 0584 1660272 <0584%20166%200272>
> mob:   +39 331 6233686 <331%20623%203686>
> http://twitter.com/geosolutions_it
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, May 8, 2017 at 11:17 AM, John, Steffen <s.john at atenekom.eu> wrote:
> Hi,
> Only third of layers are public. The rest are owned by one or two users
> withou view persmission for anyone.
> But still they appear in the capabilities document.
> Steffen
> Am Montag, den 08.05.2017, 11:12 +0200 schrieb Alessio Fabiani:
> Are those layer all public? All 300 more layers must be accessible to the
> unauthenticated users also?
> Best Regards,
> Alessio Fabiani.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> On Mon, May 8, 2017 at 10:38 AM, John, Steffen <s.john at atenekom.eu> wrote:
> Hi!
> I'm running Geonode 2.4. with approximately 300 layers. Whenever I load a
> map (containing 80 layers), it takes around 20 seconds.
> Using the developer tool of the browser, I could identify a
> GetCapabilties-Request to the geoserver, which takes around 17 seconds.
> The XML Document contains around 40000 lines, which is the reason for the
> long loading time. It contains all Capabilities of all the layers included
> in Geonode (not only the ones included in the map).
> How can I improve the performance?
> Is it possible to avoid the capabilities request or at least only load the
> capabilities of the layers which are included in the map?
> I'm thankful for any hints.
> Best!
> Steffen
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170508/5150a6e9/attachment.html>
More information about the geonode-users mailing list
