[GeoNode-users] How to use QGIS as backbone server
Rizky Maulana Nugraha rizky at kartoza.com
Sun May 21 22:16:24 PDT 2017
Hi Ragnvald,
We are trying to keep up with latest GeoNode update.
Because of the latest changes, the old geonode_qgis_server package is not working correctly.
If you are interested with our development state, you can visit
https://github.com/kartoza/geonode <https://github.com/kartoza/geonode>
Our latest changes is in master-qgis_server branch
I also made a small wiki here:
https://github.com/kartoza/geonode/wiki/QGIS-Server-Backend-Configuration <https://github.com/kartoza/geonode/wiki/QGIS-Server-Backend-Configuration>
We are planning to move the qgis_server backend package itself into GeoNode.
As I think this is also a perfect opportunity for me to raise a question about merging these changes to GeoNode,
can someone give me an advice on how to make a PR to GeoNode?
I’m concerned because I think the changes will be quite big, so I prefer if we can merge it in stages?
That way, even if QGIS Server backend is not fully functional in the first PR, we can create another smaller PR
for bugfix and improving unit tests to make sure it works tightly with GeoNode.
Jeffrey, do you have any comment on this?
Regards,
Software Developer
Kartoza
> On May 22, 2017, at 10:52, Ismail Sunni <imajimatika at gmail.com> wrote:
> Hi Ragnvald
> I cc’ed my friend in Kartoza, Rizky Maulana, who is currently the maintainer of GeoNode with QGIS Server project.
> Best Regards
>> Ismail Sunni
> Software Engineer at Kartoza
>> On 21May, 2017, at 04:54, Ragnvald Larsen <ragnvald at mindland.com <mailto:ragnvald at mindland.com>> wrote:
>> Looks like the plugin which should be in place for QGIS is not available in the general repositories. There is mention of it at the Kartoza website, and its functionality is shown in the video you refer to. So this looks very good - only the documentation needs a little friendly help :-)
>> I am very excited about geonode 2.6!
>> 2017-05-20 16:49 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com <mailto:ortelius at gmail.com>>:
>> There is a video here showing what the Kartoza folks have been working
>> on recently. I suppose one of them will pipe up with some more
>> complete answers shortly.
>> https://youtu.be/z0WYsEUNmg4 <https://youtu.be/z0WYsEUNmg4>
>> On Sat, May 20, 2017 at 7:31 AM, Ragnvald Larsen <ragnvald at mindland.com <mailto:ragnvald at mindland.com>> wrote:
>> > Thanks Jeffrey - I would still need to know how to interact with the QGIS server. Will I need to restart the geonode server before trying my luck? And how do I interface with the QGIS server? Web user interface or connect via QGIS desktop.
>> > I am no novice at using QGIS, but using and managing data/layouts using the QGIS server in a ageonode context has left me with more questions than answers.
>> > That said I will be more than happy to contribute to the docs once I get my head sbove water :-)
>> > Vennlig hilsen
>> > Ragnvald
>> >> On 20 May 2017, at 15:27, Jeffrey Johnson <ortelius at gmail.com <mailto:ortelius at gmail.com>> wrote:
>> >> The repo is here. Looks like the docs are not being published
>> >> correctly but there are in this repo.
>> >> https://github.com/kartoza/geonode_qgis_server <https://github.com/kartoza/geonode_qgis_server>
>> >> Tim or Gavin where is the best place for docs now?
>> >>> On Sat, May 20, 2017 at 3:18 AM, Ragnvald Larsen <ragnvald at mindland.com <mailto:ragnvald at mindland.com>> wrote:
>> >>> Browsing through the documentation I have found some references to a local
>> >>> settings file with references to using QGIS server instead of geoserver.
>> >>> Is there any documentation on how to set this up?
>> >>> Ragnvald
>> >>> _______________________________________________
>> >>> geonode-users mailing list
>> >>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> >>> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170522/5b042b9f/attachment-0001.html>
More information about the geonode-users mailing list
