[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Federico Gianoli alpacagis at gmail.com
Tue May 23 10:39:25 PDT 2017
Thanks a lot Alessio and Enrique,
I think we are on the right way to solve the issue... but I still have some
errors.
I really thank you for your precious help.
*$ python manage.py backup --backup-dir=/tmp/backup/*
*Before proceeding with the Backup, please ensure that:*
* 1. The backend (DB or whatever) is accessible and you have rights*
* 2. The GeoServer is up and running and reachable from this machine*
*You want to proceed? [n]|y: y*
*Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
<http://212.237.232.12/geoserver/>]' into
'/tmp/backup/2017-05-23_120201/geoserver_catalog.zip'.*
*STARTED - 1/9*
*COMPLETED - 9/9*
*Dumped GeoServer Uploaded Data from
'/usr/share/geoserver/data/data/geonode'.*
*Dumping GeoServer Vectorial Data : swl_asl*
*Dumping GeoServer Vectorial Data : c0506121_ccs2012s*
*Dumping GeoServer Vectorial Data : popolazione_veneto*
*Dumping GeoServer Vectorial Data : swl_asl_map_area*
*Dumping GeoServer Vectorial Data : contour_lines*
*Dumping GeoServer Vectorial Data : tectonic_structures*
*Dumping GeoServer Vectorial Data : gcgw_wells_tayarat*
*Dumping GeoServer Vectorial Data : main_groundwater_flow*
*Dumping GeoServer Vectorial Data : springs_perennial*
*Dumping GeoServer Vectorial Data : springs_perennial_no_data*
*Dumping GeoServer Vectorial Data : springs_temporary*
*Deactivating GeoNode Signals...*
*...done!*
*Dumping 'people' into 'people.json'.*
*Dumping 'account' into 'accounts.json'.*
*Dumping 'avatar.avatar' into 'avatars.json'.*
*Dumping 'base.backup' into 'backups.json'.*
*Dumping 'base.license' into 'licenses.json'.*
*Dumping 'base.topiccategory' into 'topiccategories.json'.*
*Dumping 'base.region' into 'regions.json'.*
*Dumping 'base.resourcebase' into 'resourcebases.json'.*
*Dumping 'base.contactrole' into 'contactroles.json'.*
*Dumping 'base.link' into 'links.json'.*
*Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.*
*Dumping 'base.spatialrepresentationtype' into
'spatialrepresentationtypes.json'.*
*Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.*
*Dumping 'guardian.groupobjectpermission' into 'groupopermissions.json'.*
*Dumping 'layers.uploadsession' into 'uploadsessions.json'.*
*Dumping 'layers.style' into 'styles.json'.*
*Dumping 'layers.layer' into 'layers.json'.*
*Dumping 'layers.attribute' into 'attributes.json'.*
*Dumping 'layers.layerfile' into 'layerfiles.json'.*
*Dumping 'maps.map' into 'maps.json'.*
*Dumping 'maps.maplayer' into 'maplayers.json'.*
*Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.*
*Dumping 'documents.document' into 'documents.json'.*
*Dumping 'taggit' into 'tags.json'.*
*Saved Media Files from '/var/www/geonode/uploaded'.*
*Saved Static Root from '/var/www/geonode/static/'.*
*Saved Static Files from '/etc/geonode/media'.*
'/usr/local/lib/python2.7/dist-packages/geonode/static'.*
*Saved Static Files from '/home/federico/gn_fede/gn_fede/static'.*
*Saved Template Files from '/etc/geonode/templates'.*
'/usr/local/lib/python2.7/dist-packages/geonode/templates'.*
*Reactivating GeoNode Signals...*
*...done!*
*Traceback (most recent call last):*
*  File "manage.py", line 11, in <module>*
*    execute_from_command_line(sys.argv)*
*  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line*
*    utility.execute()*
*  File
346, in execute*
*    self.fetch_command(subcommand).run_from_argv(self.argv)*
*  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv*
*    self.execute(*args, **cmd_options)*
line 445, in execute*
*    output = self.handle(*args, **options)*
*  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
line 243, in handle*
*    helpers.copy_tree(locale_files_folder, locale_folder)*
*  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
line 203, in copy_tree*
*    for item in os.listdir(src):*
*OSError: [Errno 2] No such file or directory:
'/home/federico/gn_fede/gn_fede/locale'*
*The restore issue:*
*$ python manage.py restore
--backup-file=/tmp/backup/2017-05-23_120201/geoserver_catalog.zipBefore
proceeding with the Restore, please ensure that: 1. The backend (DB or
whatever) is accessible and you have rights 2. The GeoServer is up and
running and reachable from this machineWARNING: The restore will overwrite
ALL GeoNode data. You want to proceed? [n]|y: yTraceback (most recent call
last):  File "manage.py", line 11, in <module>
execute_from_command_line(sys.argv)  File
354, in execute_from_command_line    utility.execute()  File
346, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)
line 394, in run_from_argv    self.execute(*args, **cmd_options)  File
"/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
445, in execute    output = self.handle(*args, **options)  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
line 87, in handle    target_folder = helpers.unzip_file(backup_file,
restore_folder)  File
line 227, in unzip_file    z.extractall(target_folder)  File
"/usr/lib/python2.7/zipfile.py", line 1040, in extractall
self.extract(zipinfo, path, pwd)  File "/usr/lib/python2.7/zipfile.py",
line 1028, in extract    return self._extract_member(member, path, pwd)
File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member
file(targetpath, "wb") as target:IOError: [Errno 13] Permission denied:
u'/tmp/restore/geoserver_catalog/store.dat.1'*
*Usuìing SUDO command, the error is different:*
$ sudo python manage.py restore --backup-file=/tmp/backup/
Before proceeding with the Restore, please ensure that:
WARNING: The restore will overwrite ALL GeoNode data. You want to proceed?
[n]|y: y
Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
'/tmp/restore/geoserver_catalog/geoserver_catalog.zip'.
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
line 346, in execute
  File "/usr/local/lib/python2.7/dist-packages/geonode/base/
management/commands/restore.py", line 97, in handle
    raise ValueError('Could not find GeoServer Backup file [' +
geoserver_bk_file + ']')
ValueError: Could not find GeoServer Backup file [/tmp/restore/geoserver_
catalog/geoserver_catalog.zip]
*Anyway, using Enrique suggestion, the system doesn't work and I have this
error:*
Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
'/tmp/backup/2017-05-23_122247/geoserver_catalog.zip'.
STARTED - 1/9
COMPLETED - 9/9
    utility.execute()
management/commands/backup.py", line 150, in handle
    helpers.copy_tree(gs_data_root, gs_data_folder)
management/commands/helpers.py", line 203, in copy_tree
OSError: [Errno 2] No such file or directory: '/usr/local/lib/python2.7/
dist-packages/geonode/../geoserver/data/geonode'
2017-05-23 18:16 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
> Hi,
> I have the same problem that Federico. A few days ago, I made that change,
> “datadir = geoserver/data”, and the backup also failed. However, when i set
> “datadir” to “geoserver/“ it works, although “geoserver_catalog” is not
> included in the backup zip file.
> Best regards,
> Enrique
> El 23 may 2017, a las 16:52, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> escribió:
> Ok, so, the GeoServer backup has been done "COMPLETED - 9/9" but there's
> an error on the backup settings.
> It looks like it cannot find the GeoServer Data Dir path on the local
> server.
> Edit this file
> geonode/base/management/commands/settings.ini
> and be sure to change this "datadir = *geoserver/data*" with the absolute
> path to the GEOSERVER_DATA_DIR
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, May 23, 2017 at 5:45 PM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
>> Hi Alessio,
>> This is the result of these commands:
>> *Before proceeding with the Backup, please ensure that: 1. The backend
>> (DB or whatever) is accessible and you have rights 2. The GeoServer is up
>> '/tmp/backup/2017-05-23_103754/geoserver_catalog.zip'.*
>> *STARTED - 1/9COMPLETED - 9/9Traceback (most recent call last):  File
>> "manage.py", line 11, in <module>    execute_from_command_line(sys.argv)
>> line 354, in execute_from_command_line    utility.execute()  File
>> line 150, in handle    helpers.copy_tree(gs_data_root, gs_data_folder)
>> File
>> line 203, in copy_tree    for item in os.listdir(src):OSError: [Errno 2] No
>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'*
>> The backup is created but with the error (*OSError: [Errno 2] No such
>> file or directory:
>> ), and the restore command doesn't work
>> --backup-file=/tmp/backup/2017-05-23_103754/geoserver_catalog.zip*
>> *Before proceeding with the Restore, please ensure that:*
>> *WARNING: The restore will overwrite ALL GeoNode data. You want to
>> proceed? [n]|y: y*
>> *  File
>> *  File
>> 346, in execute*
>> *  File
>> *  File
>> 445, in execute*
>> *  File
>> line 87, in handle*
>> *    target_folder = helpers.unzip_file(backup_file, restore_folder)*
>> *  File
>> line 227, in unzip_file*
>> *    z.extractall(target_folder)*
>> *  File "/usr/lib/python2.7/zipfile.py", line 1040, in extractall*
>> *    self.extract(zipinfo, path, pwd)*
>> *  File "/usr/lib/python2.7/zipfile.py", line 1028, in extract*
>> *    return self._extract_member(member, path, pwd)*
>> *  File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member*
>> *    file(targetpath, "wb") as target:*
>> *IOError: [Errno 13] Permission denied:
>> Thanks for your help
>> Federico
>> 2017-05-23 17:33 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> Federico, before doing anything, can you try to do this test?
>>> sudo mkdir /tmp/backup
>>> sudo chmod -Rf 777 /tmp/backup
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, May 23, 2017 at 5:24 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Hi Alessio,
>>>> thanks for your quick answer,
>>>> I have checked, but I have not the files 2 and 3 on my geonode
>>>> instance. How is it possible? I have installed geonode via ppa.
>>>> I have overwritten all "commands" folder, in order to be sure to have
>>>> the latest files, bu it is still not working.
>>>> There is another way to do the backup?
>>>> In your opinion, if I upgrade my version of geonode (2.6rc) to the last
>>>> stable (sudo apt-get upgrade   right?), this issue will be solved?
>>>> How dangerous could be for my data?
>>>> Thanks a lot
>>>> Fede
>>>> 2017-05-23 12:38 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> Digging to the source code of both GeoNode management command [1] and
>>>>> GeoServer Backup Plugin [2] and [3], seems like that GeoServer can't access
>>>>> the "${target_folder}/geoserver_catalog.zip"
>>>>> The ${target_folder} should be composed by the join of ${backup_dir}
>>>>> and ${dir_time_suffix}, something like ${backup_dir}/<time_stamp>
>>>>> where ${backup_dir} is the parameter provided when running the backup
>>>>> command from GeoNode.
>>>>> Now, the latest GeoNode code [4] tries to set chmod(777) to this
>>>>> temporary folder, which will be deleted at the end, in order to allow to
>>>>> GeoServer to write the file.
>>>>> That means that most probably the user running GeoNode must have full
>>>>> rights on the ${backup_dir} folder.
>>>>> Can you maybe try to double check this?
>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>> ase/management/commands/backup.py#L92
>>>>> [2] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>> mmunity/backup-restore/rest/src/main/java/org/geoserver/back
>>>>> uprestore/rest/BackupResource.java#L155
>>>>> [3] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>> mmunity/backup-restore/core/src/main/java/org/geoserver/back
>>>>> uprestore/Backup.java#L328
>>>>> [4] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>> ase/management/commands/backup.py#L86
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <
>>>>> alpacagis at gmail.com> wrote:
>>>>>> Hi Alessio,
>>>>>> I have checked the Geoserver Log, and here you can find the complete
>>>>>> geoserver log: https://pastebin.com/c9JeR1NU
>>>>>> The error that I have noted on the log is this one:
>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to perform
>>>>>> backup: :Could not create file.*
>>>>>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] - Compressing
>>>>>> output for mimetype: text/plain*
>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>>>>>> *org.geoserver.rest.RestletException:
>>>>>> java.lang.IllegalStateException: Could not create file.*
>>>>>> * at org.geoserver.backuprestore.re
>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.runBackup(BackupResource.java:172)*
>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.handlePost(BackupResource.java:108)*
>>>>>> The rights of  /usr/share/geoserver/data are these:
>>>>>> drwxr-xr-x  21 tomcat7 tomcat7      4096 May 23 04:49 data
>>>>>> I have also changed the folder rights adding user: tomcat7 and
>>>>>> user:user, but without any result.
>>>>>> Thanks a lot for your help and your patience
>>>>>> Federico
>>>>>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <
>>>>>>> It is possible that GeoServer cannot write to the target folder.
>>>>>>> Take a look at the GeoServer logs. Also try to rise up the log level if you
>>>>>>> don't find anything useful.
>>>>>>> This can be done from the GeoServer admin gui.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>> Hi,
>>>>>>>> which version of GeoServer are you using?
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <
>>>>>>>>> Thanks a lot Alessio,
>>>>>>>>> I have changed the files according to your suggestions,
>>>>>>>>> but now I have this error:
>>>>>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>>>>>> rights*
>>>>>>>>> machine*
>>>>>>>>> <http://212.237.232.12/geoserver/>]' into 'backup/2017-05-19_050730
>>>>>>>>> <050%20730>/geoserver_catalog.zip'.*
>>>>>>>>> *  File
>>>>>>>>> *  File
>>>>>>>>> 346, in execute*
>>>>>>>>> *  File
>>>>>>>>> *  File
>>>>>>>>> 445, in execute*
>>>>>>>>> *  File
>>>>>>>>> line 101, in handle*
>>>>>>>>> *    gs_backup = r.json()*
>>>>>>>>> *  File "/usr/lib/python2.7/dist-packages/requests/models.py",
>>>>>>>>> line 808, in json*
>>>>>>>>> *    return complexjson.loads(self.text, **kwargs)*
>>>>>>>>> *  File "/usr/lib/python2.7/json/__init__.py", line 339, in loads*
>>>>>>>>> *    return _default_decoder.decode(s)*
>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 364, in decode*
>>>>>>>>> *    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 382, in
>>>>>>>>> raw_decode*
>>>>>>>>> *    raise ValueError("No JSON object could be decoded")*
>>>>>>>>> *ValueError: No JSON object could be decoded*
>>>>>>>>> *Thanks a lot for your help*
>>>>>>>>> *Fede*
>>>>>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>>>>>>> PR here
>>>>>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>>>>>> Best Regards,
>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Italy
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>>>>>> Dear all,
>>>>>>>>>>> currently the backup and restore utility should be aligned with
>>>>>>>>>>> latest updates I guess. There are also several issues / improvements we are
>>>>>>>>>>> working on to improve this tool.
>>>>>>>>>>> We will find some spare time soon to devote to those tasks. We
>>>>>>>>>>> will send updates as soon as possible.
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Italy
>>>>>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>> Hi Federico,
>>>>>>>>>>>> there seems to be an issue in the commands, simplejson is not
>>>>>>>>>>>> available anymore, json has to be used. we should fix it.
>>>>>>>>>>>> @afabiani, is that correct?
>>>>>>>>>>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>>>>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <
>>>>>>>>>>>> alpacagis at gmail.com>:
>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>> I would like to create a backup of my geonode project and I am
>>>>>>>>>>>>> using this guide: http://docs.geonode.org
>>>>>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>>>>>> From my django admin page (Base => backups) I tried to do a
>>>>>>>>>>>>> backup, but, when I run the backup, on a fully writable folder (777), there
>>>>>>>>>>>>> is this server error:
>>>>>>>>>>>>> Internal Server Error
>>>>>>>>>>>>> The server encountered an internal error or misconfiguration
>>>>>>>>>>>>> and was unable to complete your request.
>>>>>>>>>>>>> I have double checked the settings.ini file, and I have noted
>>>>>>>>>>>>> that the configuration file is not yet update for the 2.6 version, it has
>>>>>>>>>>>>> these lines:
>>>>>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>>>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>>>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_to_24.LayerAttributesMangler,g
>>>>>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>>>>>> Is it correct? Have I to change these lines accordingly to the
>>>>>>>>>>>>> 2.6 version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>>>>>> When I try to run the backup from command line there is the
>>>>>>>>>>>>> following error about the file backup.py
>>>>>>>>>>>>> How can I solved this issue?
>>>>>>>>>>>>> Tanks a lot
>>>>>>>>>>>>> Federico
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170523/da34cf0a/attachment-0001.html>
More information about the geonode-users mailing list
